yclo
I had 2 empty modules designed for using Luxeon emitters in Surefire Turboheads, but no point using Luxeon's when SSC's are more efficient.
I think it was McGizmo that mentioned a 0.030" height difference in using the SSC in a reflector designed for Luxeon's provided an acceptable beam profile, and I confirm that it is indeed the case. For those of you that are using sandpaper + elbow grease, I have found that 0.030" is very close to the thickness of 2 Bicycle playing cards.
Bigger picture
The completed module (Downboy 750) along with the 500 lumen MN21 lamp assembly. I had to paint the top of the module with clear nail polish to isolate the + slug of the SSC to ground, I tried a thick layer of Arctic Alumina but it did not provide sufficient insulation. I wonder whether the nail polish limits the heat transfer between the slug and the module?
Bigger picture
And of course some beamshots taken last Friday, one of the foggiest night in Melbourne for a long time.
First the MN21:
Bigger picture
Then the SSC:
Bigger picture
I find that the fog provided a great medium in showing the beam distribution, much better than a standard white wall test.
Some more pictures taken on the same night:
Bigger picture
Bigger picture
Hope the dimensions will be useful to some of you that want to make modules using SSC P4's
-YC
Bigger picture
Bigger picture
First the MN21:
Bigger picture
Then the SSC:
Bigger picture
Bigger picture
Bigger picture
-YC
