PCC
The Surefire 9N that my cousin gave to me is in great working order but the B90 batteries gave up the ghost. Instead of buying new batteries I had some other ideas about this light. I came up with the idea that a 9N-2-M adapter would probably work and had someone local make it for me. What you see here is the end results of that effort.
The head is a TLS TX3 head that I had bought about a year ago. The adapter is a piece of aluminum that was turned on a lathe and threaded to fit both the 9N body without any modifications done to it as well as an M head.
A Delrin sleeve was made so that the 18650 batteries don't rattle around inside of the flashlight body.
Everything fits like it was designed this way.
The TX3 head is a two-mode head that starts off in high mode but turning it off and then back on again turns it on in low mode. If I want low mode I tap the tail button then twist the tailcap tight and I get it. Down the road I plan on changing the driver board with something better and I might change the Q5 LED for an R2 or something.
