Dawg
Can it handle RCR123 LI Ions? Forgive my ignorance on the matter. I tried searching and came up blank. Thanks.
cbdudley said:The MN03 will not handle rechargeables. Do a search on "Lumens Factory" - they make high quality lamp assemblies that are designed specifically for this application.
I have ordered LF bulbs directly from LF and it only took a few days (3-4, IIRC) to receive the order. I live in Redondo Beach, CA.Dawg said:Anyone that has them shipped to USA before? Chime in, how long to get em after the order is placed?
Thanks for responding in my thread Mark. You are absolutely correct about the Ebay scams. I do not buy much from there anymore because of the BS charges for shipping. I look forward to getting the bulbs. I am sure from what I have read here at CPF that I will be a regular customer.Mark@LF said:Dawg,
Airmail shipping normally takes 7-10 days at most to reach the US.
Yes, the shipping is low because this is exactly how much the post office charge us and we are not making money on the shipping.
Now you know how much of a rip off the guys at ebay is charging people for shipping.
Cheers,
Mark
Dawg said:Thanks guys. I will have to get a few bulbs. I tried the MN03 with 2 RCR123's for just a few seconds, and I could tell by the nice white color it was being over driven. :laughing:
Not only did it not burn out, it is still working fine. I use that particular light every night to walk my dog. Also, I just took delivery of a brand new E2D, and with them side by side, the beams are pretty much the same, as far as intensity and color. I guess the fact the bulb didn't fry is testament to Surefire quality.ampdude said:I'm surprised it didn't burn out right away. Has anybody else tried this?:thinking:
They are Tenergy 900 mah and labeled 3.0v protected. But they come off the charger usually at 4.2 volts. Just for the heck of it, I checked the very same 2 cells that I tried and have been using for the last week in another light with a KL1 and they are currently at 3.97 and 3.99v respectively. They were only used a few times lightly since the trial in the E2e. They were fresh off the charger by the way when I tried them in the E2e.ampdude said:Just to be sure, this was 4.2V RCR's and not the 3.0V ones right?
Were they fully charged? What brand and protected or protected?
Nope....not using a charger that is inappropriate with the Tenergy cells. I am using the Tenergy RCR123 charger that the batteries came packaged with. Like I stated earlier, the cells are marked 3.0 volts, but they come off the charger at over 4 volts. I just took 2 off the charger a few minutes ago and tested them at 4.11 and 4.12. I have been using these cells and charger for over a year. I have purchased the very same packaged battery and charger set for two of my friends from battery junction, and they like I, have had zero issues.So what you do is charging protected 3.0 Volts rechargeable cells in a charger meant for 3.7 Volts rechargeable cells?
I do not think this is very healthy for your cells!
There are chargers for the 3.0 Volts rechargeables, they do not top up the voltage as high as 4.2 Volts and will make your 3.0 Volts rechargeable cells last longer. And will also protect your cells from venting (and possibly flaming!)!
A rechargeable 3.7 Volts cell used with a lamp meant for 3.0 Volts battery will most certainly instaflash the lamp.
Tried in an E1e with a MN01, and the flash was really instant!
So I would advice you to get a charger suited for your rechargeables, for 3.0 Volts rechargeables..
And the Lumen Factory lamp for 6 Volts/110 Lumens IS brighter than the MN03, but the difference is not that much really.
But if you go up to 3.7 Volts rechargeables and the 7.2 Volts/150 Lumens lamp in an E2e/D, the difference will be very noticeable!
My MN01 burned like in under 30 milisecs after I lit it up on a RCR123. Don't be stupid like myself to try this.I'm surprised it didn't burn out right away. Has anybody else tried this?:thinking:
Lumens Factory bulbs on AW hi-current RCR's are better than the MN02 and primaries. Get the HO instead of EO with you want more runtime.`Going off on a tangent...if you want much longer run time with almost the same brightness as the MN03/CR123 combo, use the MN02 instead. The 03 is only brighter than the 02 for the first few minutes when the CR123's are fresh. For most or their life the MN02 will be brighter with CR123 cells. The MN02/CR123 will give longer RT than RCR123 cells/MN03 but at a little less brightness.
