RichardWad
- Joined
- Apr 9, 2019
- Messages
- 23
Correct, the pocket clip grips the pants very loosely. It is not secure, and moves around the pocket a lot.
When you say it runs like a champ on 16650, how's the low mode?
Hey guys,
Just purchased a new EDCL2-T earlier this afternoon and looking for some help until Surefire opens on Monday. I searched online and this forum, but I have not been able to find a post / article with many issues for this light. For the life of me, it bypasses low lumen output and is high output only. I removed the switch to make sure they installed the correct one and it is. When I turn the switch to constant on, it goes to high output immediately. If I keep twisting, it will blink again into high output. Only then if I rotate it backward will it go into low output mode. However, if I keep twisting backward, it will go back into high output before turning off and back into momentary only. No other way I can get it into low output mode.
For my uses at work, it is not terrible that I get 1200 lumen output instantly and always, but I will go through batteries quickly and I want the light to function properly. Have any of you guys ran into this issue and / or know of the cause and a fix without having to go through Surefire RMA? I assume it is an issue with the switch correct? Hopefully it is a simple remedy. Thanks in advance for your time and help.
Be well and stay safe.
Interesting stuff. My copy of the EDCL-2 has a super tight clip. The 16650 I tried in it for reasons I do not understand makes the light lose low mode completely. With the 16650 it is full blast all the time gas pedal switch or not. I do like the low mode and use it frequently. Thus CR123's went back into it and it now works fine. Good luck OP these SF lights are not cheap...
Other than tint, I have difficulty telling the difference between a Malkoff Neutral MDC Li-ion LMH and the EDCL-2T on low. The Malkoff is reportedly 15 lumens on low.And how low is the low?
That's certainly the case with mine and a 16650, tried it once and found it not feasible.That's some news. Virtually everyone else in this thread said that using 16650, the low was so low to the point of unusable.
Can you post pictures for comparison?
Maybe he is charging to 4.35V guys as the cell he is using is capable of that? That's what I do with my ZTA's. I would run a test but, I only have the EDCL-1T unfortunately.
Sent from my SM-N975W using Tapatalk
