nelstomlinson
- Joined
- Aug 16, 2005
- Messages
- 76
I have an older G2 which I recently picked up. The switch is flaky!
There should be nothing to go wrong. It's just a plug of metal with a spring, and when I push on it, it makes contact with the metal tube which lines the plastic flashlight. Mechanically, it seems to work fine, but the light doesn't light up.
There is a dark ring on the portion of the switch where it makes contact with the metal tube. I've tried cleaning that off, and it helps, but the ring comes back in a day or so. I've tried using nyogel on the plastic and rubber parts, and I've tried using progold on the metal parts, but neither of those seems to have changed anything.
So: does anyone have any ideas about how to make this thing as reliable as Surefires are supposed to be?
