cratz2
flashy bazook said:for the 30 minutes runtime you mention - maybe you dont' realize that the P1D CE has a 1 hour runtime on max output (135 lumens) and a 2.8 hour output on primary (72 lumens)? Which primary output is bigger than the normally available HDS top output? This is what I meant when I said the HDS is technologically behind the times.
But... but... but... I'd expect most reasonable folks will use the primary setting on the HDS more often than not so the runtime on the highest setting becomes that much less important. Of course, longest runtime and bright high setting (on a multi level light) is always important, but I've played with a P1D-CE and compared it to my lowly HDS Basic 42GT. For my uses, there is no comparison. Easy one-handed operation, large enough to get a good grip on, consistant threads, well-spaced levels which are of course, user-definable.
The Fenix is a fine light and I've certainly owned more Fenix lights than HDS lights. The P1D-CE is SUPER impressive from a gee-whiz perspective, but for daily use, I honestly don't see how anyone can actually feel that the P1D-CE is superior to the HDS. I mean, I'm glad we have both options, and of course, I wish a higher 'high' was available on the HDS but honestly, 10 lumens is plenty of light for almost all applications. If anything, the biggest issue I have with the P1D-CE and many of the multi-level Fenix is that all the settings are too high when used with Li-Ion cells. I mean, I think the P1D-CE on low is about as bright as the HDS 42 on high. That's about like having a car that can only either go 90MPH, 120MPH or 150MPH when most of the time, either 35 or 50 is the right speed.
