Sabrewolf
The "Chimera" A Twin Head 2x 18650 EDC, Pictures Included, Member List Added:
I am looking to build an EDC that uses 2x 18650 batts.
The basic dimensions would be 3 3/4in long, 2in wide,
and about 7/8in thick. It will probably resemble the
007 in shape, but different in artwork and design.
I have a great respect for Data, and his work, and not
wanting to "Copy" his design.. That would be WRONG
in every sense of the word
:shakehead
That being said..
The features would include, in no particular order:
Twin Reflectors in the front for 2 seperate led modules
with thier respecting reflectors. This would allow you to
swap different led combos around, Ie, Ultraviolet for
forensic work, and maybe a high powered green led for
blood trailing.. Or maybe, Twin MCE Quad Die/P7's
for maximum output for a short time.. The possibilities
would be endless with this setup becuase you can swap
around so many different led modules. They would slide
in from the side sort of how a gun-scope slide mount
works, but it will be flush with the body in the front.
^^^ That idea was canned for complexity sake^^^
I will be using a screw-on head design instead.
I will make up some Solidworks Drawings soon for show
and tell.
The driver would have 2 independant channels to control
the 2 seperate led modules.. This would allow you to run
one or both of the leds at a time, or even omit the
second one and slide in a blank to cover the hole.
Think of a "SLR Camera Hotshoe" for the style of slide-in
connection for the led modules. This would allow for lots
of different options besides leds.. Ie, being able to
control the light from a rifle/handgun grip switch.
The connections would be Completely waterproof and
all contacts would be stainless steel for rust resistance.
The led modules would also be thermally connected
to the body of the light by means of a silicone thermal
pad similar to what is used in Computer Cpu's.
There would also be a bettery meter not unlike the ones
i use in my maglights that i previously sold...
pics are here for the batt meter:
http://www.candlepowerforums.com/vb/showthread.php?t=206766
I will prob inlay the battery meter window in a glass,
sapphire, or some sort of gem.. but not diamond!
no epoxy will be used in this build, even though
it looks nice in the mags i had, this is NOT a Mag!
Controls will be placed on the larger part of the light.
That is the big flat area you see when you set it down
on its "Belly". I will be using Inlayed push-buttons
like what your microwave has on its front panel.
They will still have a Tactic Feel, but will have a very
long-lasting and durable switch behind it. The inlay
for the buttons will have a metal surround like a picture
frame to hold it in the light. 4 screws, one on each
corner.. The panel will be about 1in by 1.5in in size
that is machined into the body. And the driver-board
will be sitting directly below it inside the light, between
the 18650's. The driver will be about 1/4in wide and
about 1/2 tall to accomodate the components.
All the connections will be made inside the light without
any wires.. I will be using gold-plated spring contacts
that can handle alot of use. They are used by
manufactures to put in thier Bed-Of-Nails test benches.
It resembles a Toilet-Paper holder tube that has the
goofy spring inside that always pops out all over the
floor when you change the roll.. Darn thing always
rolls under the tiolet too
.. But the teeny-tiny ones
i will use don't fall apart. I will also "Pot" the driver
in epoxy for durability and water resistance. It will
come out of the light like a cartridge, and the firmware
can be upgraded too.. I want to make it this way so
that you can take the light completely apart, and clean
it out under the sink. Also, if a diver uses it, he can
just hose out the inside when he/she does a gear-check
and clean at the end of the day. The top of the driver
will have an exposed aluminim plate for conducting
heat to the body.. That way the driver components
stay cool.
The battery door will be hinged.. Nothing to loose.
All seals will be silicone, and removable too.
I will include a grease and seal kit with every light
sold.. Along with your choice of 2x led modules
of any color or type. Those led types will be detailed
later on in the prototype process.
Titanium, Aluminum, Demascus, Stainless and
even Blast-Welded Multi-Layered Metal will
be the case options.. Prices will be made up soon.
here is the blast/explosion welded metal link:
http://en.wikipedia.org/wiki/Explosion_welding
http://www.highenergymetals.com/page3.html
http://www.highenergymetals.com/page2.html
A USB charging option will be considered too.
I am looking at making 10-100 lights,
pending the forums interest of course
Okay, more to come, and my fingers are tired :laughing:
The Name for the light has been chosen, "Chimera" or Multi-Headed Beast...
Here are some Quick Renders And Sketches:
Robert M.
That being said..
and tell.
stay cool.
Robert M.
