recDNA
- Joined
- Jun 2, 2009
- Messages
- 8,761
Ah peak beam intensity 52340cd. Sounds good especially since it has some spill.
The stamp on mine is 15 01 MR...(01 mars 2015) made in Japan. Bought on september from Ncix. Keep posted with the one from Amazon.
The Eneloop Pro's came in. They have the 2014 specifications, 2014 model number, and 2014 packaging, they have"15-02 RX" engraved on the side which means they were made in February 2015. They have the 2014 specification (min 2,450 mAh) listed right on the actual battery, not just the packaging. Maximum mAh is the same (2,550). The newest 2015 ones have min 2,500 mAh, which is where the main difference seems to be (50 mAh more). You can see more in this PDF:
http://www.panasonic-eneloop.eu/pdf/99152100_ENG_eneloopCat_2015_LR.pdf
So, I got 2014 spec eneloop pro's it looks like, not that I will probably ever know the difference.
NCIX seems to have newer stock than Amazon. Mine bought in september 2015 have the capacity "Up to 2550mah". 15 01 MR engrave on the cells. I will continue to buy cells from them. Thank you for your feedback.
Both versions are "up to 2,550" though, it's just the minimum mAh that is different. What do your cells say for minimum charge? Should say right on the side like this "min.2450 mAh" or "min.2500 mAh" The 2500's are 2015, the 2450's are 2014.
I don't have the package anymore. I bought 2 sets of 4 and a set of 4 plus charger. I have the package of the charger with the cells.
http://s19.postimg.org/lljaue7k3/image.jpg
http://s19.postimg.org/qzmofomo3/image.jpg
Edit: on the cell: min 2450mah
http://s19.postimg.org/ubkz8zef7/image.jpg
The stamps of the other sets: 15 02 RX
15 02 RX
Looks like you got the exact same batteries as me, even the same manufacture date. They are the 2014 version (based on specification). The only difference between them and the 2015 version as far as I can tell is packaging, and 50 mAh minimum capacity. Pretty much a non issue I would think.
Yes, we have the same. Mine were bought in september though. I don't know if NCIX has the 5th gen now.
I checked a lot of places (NCIX, NewEgg, Amazon, Memory Express, Dell, etc.) and the true 2015's are pretty much impossible to find, looking at both the packaging and model numbers at various online retailers, everyone has the 2014 version. Even huge stores like B&H in New York don't have the true 2015 versions. Oh well!
- Bright, but not as bright as I was expecting based on all the comments and YouTube videos I watched before purchasing.
- The visible difference between 550 lumens (High) and 1150 lumens (Turbo) is shockingly small and nowhere near double (to my eye anyway), though I was just fooling around indoors
