Under Cabinet LED Question
andersonEE
Erie, PA
A friend of mine is redoing her kitchen and asked me about LED lighting options. If I was building them I'd just do some bridgelux on aluminum bar, but I think they want some commercial products.
Let's hear some recommendations. What have you guys used? What should I avoid and what has worked for you? What about cheaper alternatives from DX and such? These don't have to be perfect as they won't be the main source of light.
Thanks
Thanks
How much are you willing to pay?
Commercial LED cove lighting that is UL rated is expensive.
GE VIO makes a gorgeous product- check out their webpage/google to see. They don't use CC drive- they use CV.
Lowes, and I think Home Depot, sell a product made a company called Utilitech or Portfolio which looks to utilize what is possibly the Cree ML-E led. I have bought a bunch of the shorter bars ( 5 leds each bar) and been very happy with them. Recently the flourescent fixture above my sink died and I replaced it with a longer 27 or so inch version (8 leds) of the LED strip. The lighting is overall a very nice neutral color.
Problem is they are not cheap. Like $40-50 for the short bar and I think I spent $80 for the longer one.
I have recovered the following data from Google's cache manually.
Please post any errors and corrections in a new post below.
The format is:
Date, time, old postcount#, poster;
post data
I will try to fix the CPF links in the next 2 weeks or until I give up in frustration. Can not do that and verify with CPF down.
11-02-2010 04:42 PM #7 kaj
I'm looking at these Juno LED under cabinet lights for my house. Not cheap at all but they use Nichia LED's.
http://www.junolightinggroup.com/pr...el1=32&sel2=300&brand=1&hl=117&path=xtraMenu4
11-03-2010 06:28 AM #8 purduephotog
Yep. My depot is clearancing them out for about 30% off. Not much of a discount, they're still 50$+.
11-04-2010 05:44 PM #9 swxb12
There seem to be a ton of LED MR16 choices now on DX, even with warm-white options. The trick is to find a suitable fixture for underneath the counter.
11-06-2010 03:53 AM #10 ShineOnYouCrazyDiamond
Just as a side note to this I have been considering LED replacements for some of the flood light hi-hats I have (and they put many in this house). Main level has 9 by itself. 6 on the lower, 12 on the BR level and 3 in the attic. At 75Watts a pop you can imagine these lights create a huge lighting bill.
I've tried MANY varieties of CFL lights and finally got my wife to approve using 4 of the dimmable Phillips ones in the kitchen. I couldn't get approval for the anything in the rest of the house - because they are too whiteish and industrial looking.
Yesterday I was at the Depot looking for the 30% deal mentioned above and bought a few different options of LED hi-hat flood. The Phillips one are mega expensive and out of my reach at about $80 each but the had (what I imagine is their re-branded store brand) EcoSmart floods at $40-50 each. I purchased 4 of the regular 65W screw in bulbs for one dimmer switch and then I saw another EcoSmart one which was a full replacement for the flush-mount ceiling bracket and screw-in bulb all in one.
My results are not so good on the first bulb. Screwed in one with the 3 remaining incan floods and my first impression was that it did not dim very low. Put in all 4 and all the lights did was flicker and flash - no dimmer control at all. I have no idea who makes the internals on these.
Then I hooked up the full replacement unit to a light which only has that one light on the dimmer. Wow - this is a really great looking incan replacement for the home. I take a look at the package and who else but Cree makes the light. Rated for 575 OTF lumens @ an amazing 90 CRI. Also states clearly that it will work with multiple bulbs in dimmer setups and they even tested a variety of popular dimmers. Check it out http://cr6.creeledlighting.com/.
The model is CR6-575L but the re-branded HD model is ECO-575L.
I'm going to bring back the other floods and pick up 4 more of the CR6 lights and see how they do in a multiple light per dimmer setup. Will report back later.
