depusm12
Mods Please place this in the reviews section as well.
Had some problems with my old Inova Inforce white light so I returned it to Inova under warranty. They weren't able to fix the problem so they replaced the light with the new version. I got the light on Thursday it came in the Inova style hard case with batteries and a hex key to take off the pocket clip as well as the instrutions on use of the light. The new version has more output 225 lumens on high(vs 135 lumens for the older version), 80 on medium, 10 on low, however Inova replaced the reflector with a optic. Also the serial number is now on the pocket clip. I've used the light on duty since I received it via FedEx on Thursday. Very nice bright beam with a nice hotspot and plenty of flood as well. The led has a cool white tint to it with some slight rings in it. I'm not able to tell exactly what led that Inova is using but I suspect its probably a Cree XP-G. The light has the same type of tailcap/settings as the first generation, constant on/high, med, low/momentary high, med, low/ when you shift the tailcap to the right side it has SOS mode and further right is strobe mode. Also the tailcap button is much easier to push than the previous version I had. The SureFire 1.25" traffic cone still fits the new version as well. Overall I'm very pleased with the newer version of the light. 2 Thumbs up to Inova for improving a allready great light.
