Curious_character
- Joined
- Nov 10, 2006
- Messages
- 1,211
I recently got some regulator boards from DX which have three AMC7135 regulators on them. Although the 7135 is a passive current regulator, it can still be reasonably efficient as long as the battery voltage isn't too much higher than the LED voltage. So I've been looking into using them to modify direct drive lights. Bench measurements when driving a Cree emitter showed solid regulation down to about 3.8 volts at the battery. From there down to 3.2 volts, the output current drops about 100 mA per 100 mV of supply voltage decrease. The current is about half its regulated value at 3.4 volts. This means that the current will be regulated at least within a factor of 2:1 over the discharge range of a single Li-ion cell. Because emitters become more efficient at lower currents, it also means that the light output should drop by less than a factor of 2:1 from full charge to essentially discharged. With a 4.2 volt supply -- the highest anticipated voltage from a freshly charged Li-ion cell -- the regulator chips were cool, so no heat sinking or thermal management of the regulator board are necessary.
Encouraged by this, I put one of the regulator boards into an MTE light. The one I have originally had a Luxeon emitter, but I'd replaced the Lux some time ago with a Seoul P4. (I see that they now have a P4 installed.) This is a good light for experiments, because it has plenty of room for the regulator board and is easy to get apart. The original light was intended to run from two CR123A cells and has only a fixed resistor between the battery and LED. This resistor was replaced by the regulator board, and a single unprotected 17670 cell was used for power.
But what I found isn't what I expected at all:
As you can see, the light output dropped very rapidly to a little more than half its initial value, and continued declining for some time.
I verified that the current was holding steady at least during the initial few minutes, so that wasn't the cause of the steep drop in light output. The next suspect was heat. I watched the LED voltage for the first few minutes after turn on and found that it dropped from 3.77 to 3.40 volts. At constant current, LED voltage drops about 2.2 mV per degree C of temperature rise, so this shows that the LED temperature is rising about 168 degrees C! No wonder the light output is dropping!
For that light, I had used a star with Seoul P4 pre-mounted which I had purchased from DX. Removing the LED revealed a very thick layer of thermal compound under the LED. Thermal compound is really a very poor thermal conductor compared to metal (it just happens to be a lot better than air), so this mounting would have poor thermal conductivity. I cleaned it off and applied a very thin layer of Arctic Silver epoxy in its place. After curing, the LED voltage dropped from 3.76 to 3.62 volts in the same time period after turnon as before. The LED temperature rise is now about 64 degrees C -- 2.6 times less, and more than 100 degrees less, than before. The best I've done so far with an LED star mounted on a big heat sink is about a 32 degree C rise at 1 A, so 64 isn't bad for the flashlight.
Here's the result of the LED re-mounting, on the same graph for comparison:
The regulation is about what I expected, and it's pretty decent for such a simple and inexpensive setup.
c_c
c_c
