cal..45
hi folks,
today I was going to swap pills on my dereelight DBS. three days ago the CL1H V4 with Q2 A5 emitter arrived and I was going to check how the beam will look like in a DBS smooth.
however, the moment I unscrewed the Q5 pill from the DBS, suddenly the little domed plastic cap (I really don't know how it is called) which is centered at front of the pill came off. here is what I mean:
not a big deal, I never gave much attention to that part, until now...
curious, how the beam would alter without that cap, I screwed the pill back in and really didn't expect what I just saw:
luckily I have another Q5 pill (with cap) which I immediately tried after and the (usual) result looks like this:
one could assume, that in the first pic a smooth reflector was used and in the second an op reflector, but thats not the case. both shots were taken with the same pills (Q5 1S) and with the same light with smooth reflector. the only difference is that little plastic thingy, not attached to one of the pills. btw: both shots were taken about 4,50meters away.
now, I'm far from being an expert and could be wrong, but the hotspot without the cap is so much more focused, that I probably accidently found a way to increase the throw of the DBS quite a few meters. I'm thrilled to see how it will look outside tonight....
regards, holger
regards, holger
