I'm about to pull the trigger on a VFD and motor for a HF 8x12 lathe that will be converted to CNC. This VFD seems to be about right:
http://www.wolfautomation.com/Product.aspx?ProductID=19500
I'll use a 56 frame TEFC inverter duty motor. So here are my questions (are you out there, Barry?):
The lathe is supplied with what is supposed to be a 3/4 HP motor. Not that I believe that rating, of course. I've read everything I can find on VFD conversions and the conventional wisdom seems to be that it is a good idea to move up a little in power, especially to get enough torque at low RPMs. In this instance, the VFD is a sensorless vector type, which should help with the torque. And, the HF three-step pulleys can be retained, which will allow a reduction factor of about .46. So, should I get a 1 HP VFD and motor or spring for 1.5 HP at an additional cost of about a hundred bucks?
This VFD comes standard in a NEMA 1 enclosure and is available in NEMA 4 for another hundred bucks or so. Not having seen the NEMA 1 unit, I don't know if it would be OK in a lathe environment. I do plan to put it right on the lathe. It may well be possible to house it in a protective box but, if this is necessary for a NEMA 1 model, I may be bucks and time ahead with the NEMA 4 version.
Lastly, does anyone have a specific recommendation for the motor?
All suggestions will be much appreciated.
David
David
