bombelman said:Doable. Doing a similar mod as I type.
PM sent.
Cheers !
Valpo Hawkeye said:Huh, seems like kind of a waste to me. Defeats the purpose of the A2. Wouldn't a Kroma be easier?
bombelman said:>> Huh, seems like kind of a waste to me. Defeats the purpose of the A2.
Depends on the personal preference and purpose for a flashlight...
Yes, it would. But then you would have to be able to afford anothe 300 smacks...
CDI said:Might be, but I already have an A2, and I really don't need a Kroma. I just need low-level red and bright white, and the incan doesn't give me the runtime I want with the brightness I need.
Kiessling said:The initeresting thing about the A2 is that the low level has a different beam distribution than the hight level ... which is not th ecase for the Kroma.
Also the A2 is considerably smaller.
That said ... how would one be able to fit a LED in that small space there ... and how would the A2's driver do with a LED?
This is *very* interesting.
bernie
Valpo Hawkeye said:Won't you have to mod the regulator circuitry to increase the runtime, then? A "simply" emitter swap wouldn't do the trick, it would simply change the characteristics of the 2nd-stage beam.
