what drivers are available for 1aa
aljsk8
Wigan, UK
what is the best driver / regulator etc for a 1aa (1.2v nimh) cell flashlight im looking for 350 - 750ma (by that i mean 1 level but anything in-between those value's)
i want best efficiency and durability (if i can have both)
let me know whats available (needs to be 20mm or less in diameter)
thanks
alex
If you are concerned about run-time, you may be better going for the low end of your desired output.
You didn't mention what you are driving, so let's assume a high poer LED that has a Vf of 3V at 350mA.
Power to the LED is 3 x 0.35 = 1.05W
High efficiency drivers at this voltage are hard to find, but let's pick 80% as a rough efficiency.
Power to the driver has to be 1.05/0.8 = 1.31W
Current from a 1.2V cell is 1.31W/1.2V = 1.1Amps
That's a fairly high draw from a AA cell. If you only plan on using NiMH, one of Lambda's MiniPro drivers will put you in the range and give a fairly constant output (due to the NiMH's relatively flat discharge curve).
