I own/have owned/shot several firearms. Will relay my impressions on everything I can recall...
Pistols
Browning Buckmark .22LR target pistol. Striker-fired. Metal frame. Like all .22 autoloaders, it's sensitive to ammunition choice and needs to be well-cleaned/lubricated. Accurate due to fixed barrel and appreciable mass. Magazines aren't very good quality and expensive - recommend something like "the ultimate cliploader" to make reloading less painful if you choose one of these.
Glock 17 Full size double-stack 9mm. Striker-fired. Polymer frame. Glocks are kind of like the Honda Civic of handguns ... neither pretty nor high-performing, but they can handle the abuse and run forever. For all the detractors of "tactical tupperware", polymer-framed guns have proved amazingly durable.
Glock 21 Full size double-stack .45ACP. Striker-fired. Polymer frame. Didn't much care for it. Recoil not so manageable. I've got big hands and it was like trying to grip a 2x4.
Magnum Research Baby Eagle (Full size, I think) double-stack .45ACP. Hammer-fired. Metal frame. Heavy, severe recoil, overall unpleasing to use. Somewhat surprising since it's a CZ-75 knockoff (licensed), but then again the CZ-75 isn't made in .45...
Sig P220 Full size single stack .45ACP. Hammer-fired. Metal frame. Like it. Manageable recoil, easy to grip. Has a hammer and a decocker. Occasionally the punchline when someone asks "what 1911 should I get?".
Sig P226 Full size double-stack .40 S&W. Hammer-fired. Metal frame. Heavy to help deal with the appreciable snap of .40 S&W. Like it. Very accurate.
Sig P6 compact single-stack 9mm (joke is that it's an 80% scale P220). Hammer-fired. Metal frame. Like it. Decently accurate, mild recoil.
Sig Pro Full size double-stack 9mm. Hammer-fired. Polymer frame. Didn't shoot this a lot, but the fact that the magazine completed the lower part of the forward grip profile was a bit weird on recoil.
Springfield 1911 Full size single stack .45ACP. Metal frame. For me, this was better than the Glock 21, about the same as the P220. Shooting one was not the spiritual experience that 1911 aficionados would have had me think it was going to be.
Springfield XD-9 Full size double-stack 9mm. Striker-fired. Polymer frame. My impression of it was similar to the Glock 17. I believe it had a lower grip angle.
Springfield XD-9 subcompact Subcompact double-stack 9mm. Striker-fired. Essentially the XD-9 with a shorter barrel/slide and shorter grip. Accepts full-size magazines with a sleeve to make the grip profile identical to the full-size, leading to some weird sensations on recoil
S&W M&P 9 Full size double-stack 9mm. Striker-fired. Good ergonomics. Trigger safety is a bit weird at first.
Walther P99 Compact double-stack 9mm or .40 S&W. Striker-fired. Beautiful gun that's an ergonomic wonder. Kicks something fierce in .40 and may eject the mag when shooting one-handed (would likely be a great gun in 9mm). Available with a number of trigger configurations; the one I shot was in double/single-action - since it's striker-fired, if you decock your next shot will be in heavier double-action.
Walther PPS Subcompact single-stack 9mm. Striker-fired. I'm quite the fan of it. Intended for carry, the PPS is appreciable more "shootable" than the true pocket guns in 9mm and .380ACP that doesn't fatigue the user so terribly. OK accuracy for its size. Extended magazines (7- or 8-rd) extend the grip, leading to some weird sensations on recoil. Stock 6-rd magazine leaves no place for your pinkie finger.
Revolvers
North American Arms mini Micro revolvers in numerous rimfire calibers. I'm familiar with their 5-shot .22mag variety. Useless with the stock grip - you can't even pretend to aim since recoil will tip it up appreciably. I gather the optional folding "belt clip" grip remedies this problem, making it about as accurate as a snub-nose revolver.
Ruger Blackhawk Single-action 6-shot in a variety of calibers. It's essentially a Colt Peacemaker replica (think nearly every Western movie ever) with improved sights. I'm familiar with the ~7" barrel variety in .45LC - an immense and heavy weapon. Very manageable recoil. A bit pricey to operate in .45LC. I kind of wish I'd gotten the nearly-identical New Vaquero (without the improved sights).
Ruger GP100 Double-action 6-shot. I'm familiar with the .357 4" barrel version. Unsurprisingly, it's a bit sedate with .38 SPL and lively with hot .357 rounds. Its mass helps with the recoil with heavier loads. Single- vs double-action fire are entirely different experiences... for me, double-action will start to tear skin off my trigger finger after >50 rds of .357.
Ruger Single-Six Single-action 6-shot in .22LR / .22mag. With .22LR, this has essentially zero recoil. With .22mag, the recoil is slight. Accurate, although a bit more accurate with .22mag since .22LR is 0.222" in diameter and .22mag is 0.224". Fun to shoot.
Rifles
AR-15 Semi-automatic .223Remington / 5.56x45. The AR-15 has so many varieties that it's sort of a challenge to write a short description. I've handled them with everything from heavy 20" barrels to lightweight 14.5" barrels. Recoil is pretty manageable since the bullets are pretty light (but generally moving at >3000 FPS at the muzzle). Controls (safety, mag eject, slide release, charging handle) are fairly well thought out. Can be "sub-MoA" accurate at short ranges. Fairly affordable to operate with cheaper ammo so long as you don't abuse its semi-auto nature. The trick with the AR-15 is to avoid bolting on accessories worth 8 times more than the rifle that make it pointlessly heavy.
AK-47 knockoffs Semi-automatic 7.62x39. Build quality on these is all over the map. Ergonomics are not very good. I've handled Romanian (bottom of the barrel) and Yugoslavian (a step or two over the Romanians). These are not target rifles - their accuracy rapidly approaches "minute of man" beyond 200 yards, largely as a function of the immense bolt that rides somewhat loosely within the receiver. Recoil is subsequently unpleasant.
CETME Semi-automatic 7.62x51. Severe recoil similar to the AK-47 thanks to its even larger bolt within the receiver (this is due to its nature as a roller-delayed blowback action). These rifles maul brass to the point that using commercial .308 in them is not recommended (use milsurp 7.62x51 or steel-cased .308). Ergonomics fairly poor ... need superhuman thumbs to operate the safety and the charging handle can require appreciable force. While probably more accurate than the AK, these are less
precision rifles, more
bullet hoses. Magazines are cheap thanks to its ability to use near-identical H&K G3 magazines.
Marlin 336 Lever-action in numerous calibers. I'm familiar with the 30-30 variety. Good accuracy. Despite 30-30 being on the low end of centerfire rifle calibers in terms of muzzle energy, the 336 kicks a bit hard due to its light weight (but also handles well at the same time). I want to cry when I see these with scopes since they're brush guns and the round generally isn't effective beyond a few hundred yards.
PSL Semi-automatic 7.62x54R. Essentially a scaled-up AK-47 action chambered for x54R, which has slightly more Wheaties than .308/7.62x51. Appreciably more accurate than the AK knockoffs with similar perceived recoil thanks to the immense muzzle brake (which also makes them far louder to you and others behind it) and the crude recoil spring at the shoulder pad. Barrel length on these will remind you of the rifles that Napoleonic infantry carried. The included 4x scope is ... interesting. Expect tuning it for commercial ammunition to be a challenge.
Henry Pump Action Octagon Pump-action .22LR. These are fun, and - thanks to the regulating motion of operating a pump action - can be fired accurately in rapid succession. A bit heavy due to the barrel. Fun to shoot.
Remington 572 Fieldmaster Pump-action .22LR. Similar to the Henry, only with an internal hammer, lighter, and - in my experience - less robust internals than the newer Henry (this might be because the one I have experience with is more than 45 years old). Fun to shoot.
Ruger 10/22 Semi-automatic .22LR. A classic "plinker" rifle, the 10/22 is relatively cheap, can be decently accurate out of the box, and has a huge accessories aftermarket. Like all .22 autoloaders, it's sensitive to ammunition choice and needs to be well-cleaned/lubricated.
Savage 10FP Bolt-action in numerous calibers. I have experience with the .308 heavy barrel version. Extremely accurate with a good scope. - I regret that I never had the chance to experiment with this at ranges >100 yards.
Shotguns
Maverick Model 88 12-gauge pump-action. "Budget" model of the Mossberg 500. I've shot trap with one of these with a 28" barrel and it handles well. I've also shot buckshot from one with an 18.5" barrel and ... well ... best not to be hit with buckshot from 15 paces.
Remington 870 12-gauge pump-action. Really similar to the Model 88, only the 870 is immensely more friendly to modification.
Somewhat OT...
I'd love to get into black power. I'm presently eyeing replica 1858 Remington and 1860 Army models. Will supposedly teach you not to "race to the bottom of the magazine" since reloading is a time-consuming process.
Hi-point would be something considered budget, you lose a bit on aesthetics, but the mechanism itself is very reliable. They're clunky, brick-like guns
While Hi-points don't have the tendency to blow up in their owners' faces at the rate that numerous other "budget" guns do, I would still avoid them. They're needlessly clunky, use blowback designs on calibers that no other reputable manufacturer does, and the slides are made of a relatively fragile zinc-magnesium alloy that's not terribly durable (if it fails on rearward recoil, the back of the slide might hit you in the face).
If budget is a concern when shopping for pistols, look for a used piece in good shape. Used steel-frame S&W's and Rugers are great values in addition to being extremely durable.
