I was thinking about it at work today and had a few ideas
1. some kind of shock isolation mounting for switch/driver housings. My mag85 frequently gets loose in its bi-pin holder (brand new FM dropin bi-pin holder). Some kind of simple retrofitable thing that either holds the bi-pins in better and/or helps isolate the whole driver assembly from shocks (I understand tigerlights have something along these lines ???)
2. dual switch technology in a mag body. I have no idea how it could be retrofitted - might require brand new body. But to have something like a 1d mag body with dual switching would be awesome - I am thinking a regulated, bi-pin, lithium powered, 1D type light (kinda like
These with an AW-type switch in the normal place and a momentary-on switch in the tailcap. Something like the Pelican LAPD light would be cool, but for me I really only want a momentary on switch in the rear (I know it makes no difference in terms of running a 3-way switch - just saying...)
3. The machine work you do on mag bodies is awesome, but I think it would be nice to have a few available with the bare minimum in machining - no finning or cosmetic stuff, just resizing and/or boring, so that people could then machine and finish coat to their own tastes (or have a sleeper).
4. Speaking of my tastes, I haven't seen an 11.1v tribore in a ~3D host powered by 3P3S 17500's or 17670's with A) regulated bi-pin B) cut down and re-threaded from a 6D so the knurling goes all the way back C) med width diamond-pattern machined into the knurling D) finned AND fluted head E) lightly crenelated normal size bezel F) tailcap charging port G) tailspring resistance fix H) Surefire style dull HAIII finish I) VLOP reflector :twothumbs mmmm, yummy...
Anyways, just some thoughts.
Thanks again
-Pete
