I am looking for the brightest possible light for a rig i am building. The only problem is the max size lights i can accommodate are 150 x 25mm I was told that 1 of downloads pocket rockets would work great. Any other opinions? The light can be smaller than max size just no larger. Thanks, Randy
MG P Rocket
34 mm wide head would not fit into 25 mm.
EDC-MCE
I measured 37 mm head diameter on my EDC. Won't fit.
Practically all production 400 real OTF lumens flashlights use P7 or MCE or SST-50/90 LEDs. They all have 35 mm or bigger heads.
The only way to get 400 lumens is go custom or to way overdrive a smaller less bright.
There are a couple of suggestions to use 14500 or RCR123A batteries on lights that are designed for AA or CR123A batteries. That is pushing the batteries close to the
point. I suggest getting IMR cells which can handle the higher current. Output with the XP-G R5 lights are ~250 lumens. Some may claim more but it is for the 1st second. By the time it is 2 minutes the output has dropped.
One home made option using :mecry: DX parts :shakehead .
sku.21037 Cree MC-E LED 3-Mode 410-Lumen Drop-in Module w/Copper Heatsink Base (26.5mm*27.5mm)
sku.14905 MX Power 3W Cree P4-WC 150-Lumen LED Flashlight - Gray (1*CR123A)
AW's IMR16340
http://www.cpfmarketplace.com/mp/showthread.php?p=2272984#post2272984
If you read the reviews on the MCE module page a few people have tried this.
Note: The normal Lithium ion is pushing out 2000 mA in this setup. The safe limit for that kind of cells is 1400 mA (2C*700mA).
So get the IMRs!
