I have a CR123a 3.0 volt battery as seen from the below picture
Rechargeable RCR123A Lithium LiFe Batteries
Capacity: 900mah
Voltage: 3 volts
when I tested the voltage with a battery tester, the actual voltage is 3.3 volts
can some kind souls please use a battery tester to take the actual voltage of a new Surefire 3.0v battery?
What is its actual voltage?
will 2 of the above batteries work with the LX2?
:candle:
Capacity: 900mah
Voltage: 3 volts
:candle:
