Where can I buy a power hid 100-200w ballast and lamp?
c_dos_vtr_110
Spain
I have got a mod flashlight with hid 35w with A123.
Where can I buy a ballast and lamp of 100 - 200 watts hid?
With ballast digital of kit 35w, Can it run lamps of 55w?
Thank you.
Uh, well for starters, it's been over two years since you started this thread.
You probably didn't get a response because it's not really clear what you're asking. It looks like you have a few questions, and they don't seem to be related.
First, to find a ballast and lamp that are 100-200W (Probably 175 is going to be the best bet), you should specify what type you are looking for, and the intended application.
Your other question seems to be whether you can run a 55W HID lamp with a 35W ballast. The answer is probably. I think that most "55W" retrofit kits like you'd find in automotive bases are in fact 35W bulbs paired with 55W(ish) ballasts.
up to 100W HID kits, easily bought on ebay or aliexpress.
Higher than that, I haven't seen it as theses are developed for cars.
Yes, you can run 55w bulb on 35W ballast, but it will not give you 55W,
the power is dictated by ballast.
