cy said:
hey Al carries his M6 around all the time too...
That's one bad *** light man. Just too big for pocket carry is all.
it's not unusual to find KL4's with 100+ lumens. if you have an Xbin KL4, then more output yet
You don't mean on an L4 body though right? Something doesn't add up here. I researched the crap out of the L1, L2, and L4 earlier this year and Surefire's site listed the L4 as being either 65 or 70 lumens. Now it says 100 lumens. They still claim 2.5 hours of run time on the L4, but only 1 hour for the L2 on high, which they also list at 100 lumens.
Beyond that, I've done head to head comparisons of the L4 (a friend's) and my L2, and the L2 is clearly brighter. Not "lots" brighter, but you can see the differences when shining them on the same surface. Further, during this same comparison, the L2 seemed brighter than an E2E (65 lumens), and the L4 seemed to be right on the money brightness wise with the E2E.
you must either have an unusally dim KL4 or are not doing a fair comparison. note final output depends upon luxeon lottery.
I suppose this is possible, but I'm skeptical. Have you ever seen large differences between two Surefire samples of the same light? As a premium product, I wouldn't expect easy to see brightness variations. Plus see above about comparisons with E2E.
note not all KL4 will run in regulation in 1x CR123. whereas all KL4 will run in regulation with R123 li-ion.
I'm not sure what regulation has to do with this. Regulation, in flashlight terms, means constant brightness output right? If so, it doesn't play into my comparisons, as no light was on for more than about 1 to 1.5 minutes at a time; usually far less. For the record, all tests were done with disposable 123A lithiums.
white ceiling beam tests seems to be favored for output comparisons. not everyone has access to an integrated sphere.
I certainly don't!
We used a table in front of us and a white wall and door at about 15 feet away for the comparisons. Again, the hot spot of the U60 was much brighter than the KL4 head, particularly on an E1E body. Overall output of the KL4 on the L4 body (two batteries) could have been brighter than the U60; it was fairly close; again the hot spot throws off my ability to discern total light output.
Finally, note that flashlightreviews shows total light output of the L2 at "72", the L4 at "58", and the U60 at "44". If we pretend that a "72" is 100 lumens, that makes the L4 right at 80 lumens, and the U60 about 61 lumens. Chart:
http://www.flashlightreviews.com/features/chart_manu.htm
This seems fairly consistent with my experiences. What are you basing your statements upon? I.E., have you done "eyeball" tests like mine, or with measuring equipment, or something else?
Thanks,
Brian.
