Forgive me for a stupid question in poor English. I'm new to this forum and have very litle experiences about HID flashlights. I have recently purchased my first HID flashlight, a G&P Scorpion. According to the manufacturer it delivers 3500 lumen, but I feel that it is actually not more than max. 2600-2800.
After about 60 min usage the burner has given up. (I used the torch for short, (<1 min) periods in very frequent cycles. Some type of discharge lamps can be damaged of similar on-off switching. What about HID halid bulbs?
- Can I use some other type of burner, and where can I buy it.
- Can anybody recommend a real 3500 lumen torchlight with good quality, for affordable price?
Hello
Phoenix246. There's never a stupid question around here friend and I understand your English perfectly.
Very sorry to hear that your light is no longer working. Unfortunately the G&P Scorpion had some know issues ever since it's introduction. One of the first test units which was reviewed by CPF members actually failed because the of an issue with the ballast. According to the reviewer, the ballast has insufficient heat sinking. The other problem had to do with a weak handle attachment method and poor water resistance. Due to these problems, one CPF dealer who was going to bring these to market for us decided not to.
You're probably accurate in saying that the Scorpion is probably closer to 2600-2800 lumens at best. I've never handled or operated one myself or done my own comparisons but it's very common for compact, 35W Asian HID lights to be well below the stated output specs. Additionally, because of the bulb's blue-ish 6000+K color temperature, they produce still further lumens than they would if the color was closer to 4200K.
Regarding the frequent turning on and off of the light, it's true that it will be harder on the components like the bulb and ballast. Some lights like the Polarion are rated for frequent on and off use but still, it's going to reduce the lifespan of the bulb some. As a general HID rule, it's best to run the light for at least several minutes and then let it cool for at least several minutes before turning back on again. Not following the general rule isn't going to ruin your HID light instantly, but over many months of frequent use it will have a negative effect. What the effect is will depend on the individual type of light and components used.
Regarding using a different type of burner, (I assume that you're talking about the bulb) your going to have to continue using HID type bulbs, either from the original manufacturer, or from another manufacturer who offers bulbs of the same specification. The term "HID" describes a wide range of lamps which uses a high intensity arc between two tungsten electrodes. Xenon-short arc, Metal halide, Mercury vapor, Sodium vapor are a few examples of the main types, but they're all HID.
Your choices of true 3500 lumens lights will be limited because in most cases 35W HID's are not capable of producing that output unless they're over-driven quite hard, reducing the bulb and component life. Although 3200 lumens is possible, very few HID lights use 4200K bulbs which are needed to attain that output. I'll list a few 35W lights that are capable of 3200 lumens.
N30 (from Battery Junction) (around $150)
L35 (soon to be released for sale from Battery Junction, see the L35 thread) (around $325)
RL-11 also known as the A3100 (available from Magnalight) (about $400)
Streamlight HID Litebox (available from BrightGuy) (about $400 but it's huge and uses a SLA battery)
Xe-35 from Xevision
http://xevision.com/hid_searchlights.html
Polarion X1
http://www.polarion-store.com/pd_polarion_x1.cfm
Obviosly the X1 is not in everyone's price range. It is now produced as a 40W light but used to be a 35W light. You might contact Ken Good at Polarion to see of the 35W is available any longer or check with these guys here:
https://www.4sevens.com/product_info.php?cPath=87&products_id=415
Also, if you're interested in a 35W X1 you might place a want add in the CPF marketplace to see if anyone is interested in selling. You might be able to pick one up an a big discount.
Hope that answers your questions and gets you pointed in the right direction.
