Nano-Oil.com
the true shelf like of a good alkaline cell is much more then 5 years,A set of "heavy duty" will go years in a remote. Lithium and alkaline AAs are about the same capacitor at drain levels of clocks, remotes, etc.
Lithiums are good for high draw stuff, or extremely low load stuff where battery life is limited by the shelf life of regular alkalines.
When we find flashlight still in packages from 1998 , I run for my voltmeter and take a reading, just about all of them still have 1.6v in them we are now almost in 2014 I always go WOW!
In 1998 we receive a purchase order an opening order of 40,000 2x5mm LED flashlights from the C.Crane Company, each flashlights hosted 3 AA alkaline, so we went from buying batteries from Costco to actually sourcing the best we could find Made in America, of course at that level of buying pennies count but we there were no way we could have compromised on quality since the warranty on those flashlights carries a life time.
Shortly before the PO came in,I had the great pleasure to meet an official from the world player in synthetic graphite manufacturer in Switzerland who knew who is who in the world of energy storage,
He connected us with a company in Canada who just was taken over by its employees after Duracell closed shop.
We ended up with Duracell quality AA alkaline delivered to us in shipments of 20,000 cells per week at the cost of US$ 0.09 LANDED IN PETALUMA (meaning shipping cost included).
The point of my telling you this little point in history is record and statistics which holds true to batteries from any manufacturer.
the alkaline batteries that you see someday in your device that have leaked and corroded your electronic or what have you were actually defective from the day they were born in at the factory.
Mostly it has to do with the insulator ring that is on the negative - end on Alkalines
some of them are already faulty from any factories and it is a known fact to them, it is a rather low percentage but it is an acceptable rate to them.
I came to know those facts when I called the factory to investigate since we were now sensitive to potential returns in big numbers due to faulty $ 0.009 batteries on devices sold for $ 32.00 a piece, the math is easy.
so part of our Quality Control QC was to inspect the negative side of batteries before insertion into the flashlights,
that was a fairly easy task,
1-take a box of AA bulk
2-invert it upside down and open with a razor blade the what was the bottom of the box.
3-put a sheet of paper over to cover all negative end of batteries.
4-apply force using silicone pad 1/4 inch on a press and walk away
5- come back 30 minutes later and read the page
6- use a magnet to remove the bad ones replacing it with a known good one each time else things can go crazy.
I even found some with no rings at all, needless to say they contained NO CHARGE AT ALL
Have you noticed that the corrosion is always on the negative side on alkaline.
I am grateful for this thread as it brings some very fond memories.
