nzbazza
Just noticed on the Zebralight.com website details for the H501.
Link Here
Basically the H501 is a H30 powered by a single AA battery (alk, ni-mh, lith pri, Li-ion).
H501 Headlamp
Sorry, temporarily out of stock
$59.00
The H501 is a high performance, versatile, all aluminum headlamp. The H501 can also be used as a general purpose angled flashlight without its headband. Three light levels spread far apart, easily selected with a pushbutton switch. Powered with one AA size battery, the H501 can produce a maximum of 96 Lumens of smooth flood light.
Main Features and Specifications
Meets IP68 in accordance with IEC 60529
Link Here
H501 Headlamp
$59.00
- Light Output: Constant ratio output level spread. Current regulated.
- 96 Lumens (2.3 hr) on High
- 18 Lumens (19 hr) on Medium
- 3.3 Lumens (3.5 days) on Low
- LED: CREE XLamp XR-E Q5
- Dimensions
- Diameter 18.5 mm (3/4")
- Height 71.2 mm (2 3/4")
- Battery: One AA size alkaline, 1.5v lithium primary, NiMH rechargeable, or 3.7v 14500 Li-ion rechargeable. Reverse polarity protection.
- Beam Type: 80 degree flood, with no hotspot
- Constructions
- Soft touch pushbutton switch, with a minimum operating life of one million cycles.
- Recessed impact resistant LEXAN polycarbonate lens.
- Precision 3D machined casing from premium grade Alcoa aluminum alloy billet, light weight with superior structural strength.
- Electrically conductive aluminum body provides inherent EMI/RFI shielding.
- Durable hard anodized finish.
- Dust-tight
- Protected against continuous immersion (1 meter, >30 minutes)
- From Off
- Press and hold to cycle through Low, Med and High, release to set.
- Click to High, click again quickly to cycle through Med, Low and High.
- When On
- Click to Off.
