SlowInTheDark
- Joined
- Dec 11, 2009
- Messages
- 4
Hi all
I have a zebralight H501 headlamp and use it a lot. I have a question about the UI.
If I turn the headlamp off from 'Medium' mode, and then turn it back on in 'Low' mode, the headlamp gives a momentary flash of 'High' before reverting to 'Low' mode.
This momentary 'High' flash only happens when the headlamp has been previously turned off from 'Medium' mode.
If previously turned off from 'High' or 'Low' mode, then re-starting in 'Low' mode works perfectly (no 'High' flash).
I haven't read of this phenomenon anywhere on the Forums, and I'm curious to know whether all H501 headlamps work this way. Does yours?
Thanks
SITD
Thanks
SITD
