I just bought two of these, and I am really pleased with them. The even, wide beam with no hot spots and the very neutral color is perfect for my needs.
The one thing I can't figure out is the switching system. In theory (I believe), when you click on the button once, it goes to high. When you click again after a bit, it is supposed to shut off. Both of mine do this, but not always. Sometimes instead of shutting off completely, they go to the low setting. This is dim enough that it is very easy to think they've shut off, but instead, it's slowly running the battery down.
If I hit the switch a few times in quick succession, I can sometimes get it back into the proper on-off mode. I'm running them off of normal alkaline AA cells at the moment.
Has anyone else experienced this? Is there something I'm missing or doing that gets them into this mode? I can probably live with double checking them to make sure they are truly off, but it's annoying.
