eraursls1984
Zebralights don't even have PWM....In lights like ZL where the pwm is too fast to be seen...
Fast PWM: No tint shift, but may be much less efficient at low power settings.
Current control: may tint shift quite dramatically at low power, but provides the best efficiency. Battery life at lowest power settings can be dramatically longer than a PWM light.
Didn't take long for the denial. PWM is rapid on/off where the LED light output drops to zero. It has been clearly demonstrated in other threads on CPF that ZebraLight drivers don't technically utilize PWM strictly speaking, but the evidence presented, and the oscilliscope measurements prove, whatever you want to call it, it most certainly is not Constant Current, but something much closer in form to PWM than CC.
If no one really cares, let's just call it PWM for the sake of intellectual honesty, at the expense of technical accuracy.
Fireclaw18, you have boiled it down to all that could matter, and done so with brevity.
But it should be mentioned that the light levels we're talking about, with the worst tint shift with CC, are extremely low light levels, especially the sublumenal. Human eyes, when dark adapted to see when light levels are subluminal, can't distinguish color very well. Though tint for the sake of tint is it's own reward (tint snobs know), the tint that is best at rendering color won't matter as much at those low levels. So though this competition between tint shift and efficiency is all there really is to the PWM vs CC argument (for those that don't mind PWM), the emphasis on this tint shift is exaggerated, while efficiency seems to be disregarded as not important, in comparison.
You seem to be forgetting that ZL makes some of smallest, most efficient drivers in the industry.
None of you guys(PWM/Pulsing/creative camera work whiners) have any idea why ZL does what it does with it's drivers. You know next to nothing about driver design and most of you don't even fully understand simple electronic algorithms. You also seam to claim there is some massive downside to the system ZL is using in some of it's lights yet it can't be seen by the human eye, can't be seen by under normal filming or photography conditions, and has no other proven ill effects. You can only produce any evidence by creative camera work and/or waving your lights around like an 8 year old baton twirling kid at a school talent show.
So, ZL is pretty much the industry leader in driver design, they have excellent efficiency/runtimes(better then most other brands), you like their other features, you can't see any ill effects under normal usage or filming conditions yet you still make a huge deal out of some tiny algorithm anomaly. I just don't get it. I really think you guys need to get a life and quit cluttering up half the threads in CPF with your obsessive blabber. If you already didn't notice, it is annoying a lot of people and taking away from the great atmosphere here at CPF. You already have a thread about PWM so, why don't we keep the PWM/Pulsing/CC/etc. discussion in there and stop derailing and causing arguments in half the threads on CPF. I for one am sick of it and it sure seems many other are as well.
I agree that any post about whether PWM is an issue, or not, is a waste of opinions.Jon slider and Chillinn, your PWM crusade is driving people nuts. Please please please drop it!
I posted in the main ZL thread a few days ago but I'll post a summary here too. I emailed them and they said they're hoping for a late March or early April release date for this light. However, they don't plan on putting the new programmable UI into it. They said they'll release that in one of their 18650 lights later this year.
Sad it won't have the programmable UI. The only thing I'd actually change is to make medium a single click and high a double click from off. My only complaint with my SC52 is that it's slow to access medium without a high flash. Probably 90% of my usage is medium and I only rarely use high. Hopefully there will be an SC53c with programmable driver and the same emitter.
Yeah that's kinda what I've ended up with. I have my H2 set to the lowest value but it still goes through battery over twice as fast as M1 and four times faster than M2I set mine up to have the lowest high setting so when I single click it will go directly to that. It's not that much brighter than the medium setting and is the best work around I've found. For the way I use my SC5w it covers most of my intended applications and I rarely need medium or the brighter H1 setting. With this setup I mainly press and hold for my low modes or single click for the lowest high. Works great
The medium modes need tweaking to make it perfect. This is true for the AA and 18650 versions. The lowest M2 is too close to L1, and the highest M2 is too close to M1. If it could split the difference it would be perfect for the AA models, and good enough for the 18650. For the 18650 to be perfect, IMO, I would use the highest M2 and the lowest H2 as M1. I also hope we can enable more than 2 modes for each subset.Thanks for the update. That's just fine. The smaller output range of 1-AA lights naturally does away with perceived gaps in useful output levels. It's when the range is broad, as in the case of 18650 lights, and only a handful of modes can be directly access, as in the case with ZL's UI, that tough compromises with regard to what modes to keep and hide are necessary. With the new programmable UI, let's hope folks will have more options and their lights become even more useful.
