Really?! As in no green/yellow tint? Would you characterize it as a slight rose tint similar to Nichia's 219? My hope is that ZL is starting to use the same great 4400K XM-L2 that so consistently present in the H52w. I had given up hope that that I'd ever be able to acquire a good neutral tint in the SC52w L2 platform...
It is yellowish. If I were being very picky, I would say the spot's corona is
slighty greenish at lower outputs, but that is only evident when comparing directly to other warm tints. It never appears green to me by itself, but it also isn't "rosy" like a Nichia. Comparing other lights, the tint appears nearly identical to a 5B2 XP-G that I have in a Nailbender drop-in.
I consider myself fairly sensitive to greenish and bluish tints and, like yourself, was concerned with all the disappointing comments about the tint of the SC52w's, but I'm completely satisfied with the tint of this one. With that said, I don't want to give anyone a false sense of security, as I think there is good evidence that a "tint lottery" is at play. Also, it's my opinion that the AR coating that Zebra is using on their lights is creating some tint shift across the beam profile, causing the spill to be cooler than the spot.
