- MM L1P : 1,7w (Lux @490mA) -
- MM L2P : 3,3w (Lux @980mA) - double the voltage, double the current, double the power.
- MM L1P with 3,7 Li-ion : I suppose it's 5w (Lux @~1500mA ?). But not sure at 100%.
I will put a SWOH in my MM L1P because it's 1,7w and SWOH is a 1w Lux.
SWOH will be little overdriven.
And I've putted a UWOJ in my MM L2P (3,3w), UWOJ is a 3w Lux.
Little overdriven too.
When I use UWOJ at 1,7w (Lux driven @ 490mA), the brightness is still very good, but the tint is a vey little more yellowish.
Because the tint of a LuxIII (UWOJ in my case) is tested for 700mA.
I prefer to use a SWOH at 1,7w, the tint of LuxI (SWOH) is tested for 350mA.
The circuit driver in the MM L1P and MM L2P head are exactly the same.
Concerning the use of a Li-ion 3,7v with the Millermod circuit, I've had in the past asked the same question. His answer :
Q : In the MM L1P + UWOJ, can I use 14500 3,7V Li-ion accu with no problem ?
A : Not unless I beefed up the barrier diode to handle the current when using Li-ion. It's best to an L-bin or higher Lux when using Li-ion with my driver.
Q : Any risk for the driver or the Lux ?
A : No problems in my experience; the Luxes can generally handle 1500mA as long as the heat is shed properly.
Kalinux said:
What about MM L1P with 3.7v AA,
I was thinking that MM L1P and L2P is the same.
Could you explain why S**H for L1 and U**J for L2
