Darell
That's right folks. A non-flashlight mod! With LED's no less. That's right - LEDs aren't just for flashlights anymore!
Each reading light is individually switched on the headboard. The blue uplight (single 3mm 320 Nichia) is very wide-angle and creates a perfect blue glow in the entire bedroom. The up-light is used as a nightlight until the entire system is switched off. The system is switched remotely with an X-10 module, so the nightlight can be turned on from downstairs - then the system can be turned off from either night stand.
The reading lights are Tri-clusters from BerkelyPoint.
Did I mention that I really like LEDs?
