laxbum said:
What batteries would you suggest for the L1T? What will give it the brightest output and best run time?
The light will give very similar initial output on typical battery types. On high, you will decline relatively rapidly on alkaline (i.e. only semi-regulated), giving you maybe 1.5 hours to 50% initial output with a good brand alkaline (less on cheapo/no-name ones). But that being said, some inexpensive name-brand alkalines (like rayovac, memorex, etc. ) can be almost as good as as duracells or energizers. Much better output on NiMH or Energizer e2 Lithiums - light remains much brighter longer, with at least 2.5 hours on modern NiMH, and close to 3 hours on lithium.
On low, the light is very well regulated on all types. Expect at ~7-8 hours on alkaline, ~10+ hours on NiMH, and ~13-14 hours on e2 lithium.
Check out flashlightreviews.com and chevrofreak's excellent runtime graphs here on CPF for more details. My own testing matches very closely to chevro's results.
You can also run it on 14500 lithium ion rechargeables (I recommend the protected kind - you will also need a DSP charger). While initially much brighter (closer to the L2T, in fact), it will rapidly decay (although stay brighter than a standard battery would), and then cut-out completely without warning around 40-45 mins or so.
If you are planning on running the light regularly, NiMH is probably the best way to go. If it's only going to be for intermittent use and stored for periods of time (when NiMH would self-discharge), lithium is a great option (great storage capacity in cold conditions especially). And of course, you can always pop in commonly available alkalines whenever the need arises.
