flashy bazook
- Joined
- Jan 7, 2007
- Messages
- 1,139
Remember those nice looking Molle Pentagon Lights from the SHOT SHOW? They are can now be pre-ordered, at $32, to be available from March 1.
http://www.pentagonlight.com/item_detail.cfm__id.487
Description
Bringing back the anglehead design of the past for today's MOLLE equipped gears, it fits through PALs webbing for secured hands-free attachment on MOLLE vests and compatible equipment. The top-positioned button enables operation without removing from the webbing. Rotate clip to the back for carrying in front of a pocket or other clippable surfaces. Rotate clip to the side for attaching to regular belts or duty belts. Its anglehead design provides personal illumination anywhere, anytime simply with a push of its top-positioned button. High efficiency LED provides up to 30 lumens of light output. This shockproof light source has over 5,000 service hours, making bulb-changing a nusiance of the past. A red filter is included for providing low visibility light and is useful for map reading and plotting aviation charts. Filter can be secured in the base of the light when not in use.
Specifications
Brightness: 30 Lumens
Run-Time: 3 Hours
Batteries: One AA Alkaline
Lamp: 0.5 Watt White LED
Filter Color: Red
Length: 3.4" (86 mm)
Weight: 1.5 oz. (42 gFeatures
* MOLLE PALs Webbing Compatible
* Hands-Free Illumination
* Rotatable Clip
Pre-Order Now. Available on March 1, 2007
Warranty: Limited LifetimeModel #: LM1-DT
Rotate clip for attaching to other locations, such as pockets and belts.
Description
MOLLELightWarranty: Limited LifetimeModel #: LM1-DT
Description
Specifications
Run-Time: 3 Hours
Filter Color: Red
* Rotatable Clip
