Gransee
Greetings!
As some of you may know, we at Arc Flashlight have been quietly working on several new products for the past 6 months.
Some of you have speculated on what we would release. In forum posts and chat rooms, people have asked me to provide some sort of glimpse into the future of Arc. I apologize that I haven't always been able to talk about what we have been working on.
But the projects have now progressed far enough that we can announce them for release this winter.
All of these new designs center on versions of the "Luxeon Star" (LS) flashlight we first introduced to the public last year. The Arc-LS was the first production flashlight available with the new LS LED as a light source.
As most "flash-a-holics" can tell you, the LS LED is much brighter than the 5mm types typically found in LED flashlights. This increased power output has allowed us to create the kind of lights you have asked for. Lights that are much more compact and powerful.
The Arc-LS is a light ahead of it's time. And it has had some teething problems. We have made many improvements to the basic design since last year.
About 6 months ago, we came to the conclusion that to improve the light to the next level, an entirely redesign would be necessary. We are calling this new design phase, "Revision 2". Or simply, "Rev2".
Rev2 includes a new housing, power packs, circuit and support for new LEDs.
Note: we will post pictures later on as these units start coming from production.
The current Arc-LS version is called the "LS1". It uses the rev1 parts with the Low Dome LS emitter.
The rev2 parts are as follows:
Rev2 Housing
- Waterproof to 50ft
- Slightly smaller in diameter than LS1
- One piece head construction limits anodize mismatch
- NX05 optics protected behind AR coated Lexan
- New heat sink design increases heat dissipation by several times compared to the rev1 housing
- Gold button contact
- Compatible with rev1 and rev2 power packs
Rev2 Power Packs
- Slightly longer than rev1 counterparts to make room for new tail switch
- Battery retention spring replaces rev1 retainer and allows better battery management
- Waterproof to 50 feet
- User replaceable tail switch
- Tail switch is dual mode: light press for momentary, full press for latching on/off
- 1AA size discontinued, new 2x123 size announced. This brings the total packs to 1x123 (default for all LS series), 2x123, 2xAA)
- Backwards compatible with rev1 housings
Rev2 Circuit (PCB)
- Designed and tested by CPF's very own designer, "Dat2Zip" (Wayne). We looked at several designs from the CPF and elsewhere. Wayne simply blew away the competition in meeting our strict requirements.
Wayne has signed a NDA so please do not ask him for details on our circuit
- Current regulated for more consistent response and better protection
- Much higher power output than rev1
- Thermally protected
- Very compact (allowing a smaller housing to be used)
- 1.4v cutoff prevents the use of the 1AA pack but does protect rechargeable cells from excessive discharge
- Higher efficiency than the rev1
- Aggressive heat sink measures taken for future LED capacity. Extended testing with high power emitters.
Here's our timeline:
September:
Rev2 123 Power Pack ($30 SRP)
October:
Rev2 Housing
Rev2 PCB
New High Dome Whites ("LS2")($150 SRP)
November:
Rev2 2xAA Power Pack ($40 SRP)
Rev2 2x123 Power Pack ($40 SRP)
New 2W white model ("LS3") ($200 SRP)
Note, to keep our product line simple. We will only be making the LS1 and LS2 for a short time. The LS3 will then replace all previous versions.
Note: Prices shown are for a complete flashlight! We do not require you to buy extra bodies, bezels, etc just to cobble together a working flashlight. We ship you a complete solution optimized for LED technology.
LS1 ($120 list)
1W Low Dome White emitter, all rev1 parts
Package includes head and p-123 pack (rev1)
LS2 ($150 list)
1W High Dome white Emitter, Rev2 parts
Package includes head, p-123 pack (rev2), Duracell 123, and nylon carry case with Arc logo.
LS3 ($200 list)
5W High Dome White Emitter driven at 2watts. All rev2 parts
Will become standard product
Package includes head, p-123 pack, Duracell and nylon case
Custom made Arc 123 Nylon case is a special item and not sold separately.
P-123 ($30 list)
1x123 power pack w/tail switch and lanyard loop
P-2X123 ($40 list)
2x123 power pack w/tail switch and lanyard loop
P-2AA ($40 list)
2xAA power pack w/tail switch and lanyard loop
Why are we derating the 5W emitter at 2W in our designs? Heat and run time is the reason. Even at this power level, this light is very warm during normal operation.
The default pack for the 2W is the 1x123 pack. The optional 2x123 pack ($40) overdrives the design to about 3 watts of power. The flashlight is very hot after 20 minutes with this pack. Run time with 1 123 cell at 2 watts or 2 123 cells at 3 watts is about 1 hour. Run time with 2 AA NiMHs at less than 2 watts is about 1 hour as well.
The LS3 beam is about 4x larger than the LS2 beam. The LS2 beam is about 1/2 as large (more focused) than the LS1 beam. These lights are best for illuminating targets in the medium range.
Future accessories planned include an 'A' size rechargeable pack, switch guard (allows standing on end, etc) and clip.
The LS is only offered in white LED and Natural HA finish.
Factory seconds of each model may become available at a discount.
Dealer prices will vary. Stock will be limited!
Peter Gransee
Arc Flashlight
Rev2 Housing
Rev2 Power Packs
Rev2 Circuit (PCB)
September:
October:
Rev2 Housing
Rev2 PCB
November:
LS1 ($120 list)
LS2 ($150 list)
LS3 ($200 list)
P-123 ($30 list)
P-2X123 ($40 list)
P-2AA ($40 list)
Peter Gransee
Arc Flashlight
