I was in the market for a Beast II when I received a new HID light for evaluation from a company called Group 5 Engineering (www.group5engineering.com), called the HB-1.
About the same size as the Beast and made of 7000 series aluminum (used for aircraft wing spar and load bearing components), it is simpler in its design, with fewer parts.
The reflector is a Group 5 design, and comes in two different head sizes, which could be described as large (HB-1), and larger (HB-2). This reflector is a bespoke design. Very efficient.
What attracted me to the light was its simple design and strength, along with its light output, which at 5900 lumens, is about 3X brighter than the Beast.
With adequate mass and a pyrex lens, there is no heat problem when handling the HB-1.
Priced at under $3000, The HB doesn't have the LEDs that the Beast has, but it is brighter.
I did do a quick comparison at a gun shop that had a Beast II, and found that the HB-1 was brighter, by a huge margin. The HB lit up a building across the 6 lane wide street in daylight, where the $4,500 Beast could just make the address sign reflect. At short range, it simply obliterated the light output of the competing HID flashlight.
Using a set of disposable 123's, it runs for about an 1hr+15. A lithium pack may be available, but it just wont last as long, and rechargeable lithium batteries have a habit of catching fire in hot environments, such as car trunks (I am qualified on this one). I will stick to the 123s and an extra magazine of batteries.
My intended use for the light is to chase coyotes from my property, which has a pond and swans, evidently a favorite delicacy of coyotes.
In testing it, the coyotes ran, but the raccoons stood up and danced.
The thing is big and heavy, but when I need light, it makes just about everything available look like a jar full of fire flies.
Outside of a helicopter born Night Sun, it is the brightest hand held light that I have ever seen.
I would post some photos taken across a canyon under a full moon, but I am not allowed to attach photos here.
