leon2245
- Joined
- Apr 4, 2008
- Messages
- 2,335
The Mentor for instance specifically states:
While the Trust Model 1, which also has the Smart UI, you can apparently only do so with high (no four & a half press trick with this one?):
Just an omission, or really not possible with the Trust Model 1 (or any of their 1xAA's)?
SMART UI: 3 levels, with memory (last level used) and you can also lock it into any 1 mode using 4 1/2 presses. So the light becomes a single mode with a tactical style interface.
Leaving the head tightened snug will put the light in Maximum output mode. Loosening the head 1/4 of turn will place the light in a Smart UI where the 3 brightness levels are selected with momentary on/off from the tailcap.
