I have been wondering about what's inside of Pila IBC charger. Last night, I opened my Pila charger and took pictures of its inside.
The case doesn't look like some easy to break brittle plastic material, it feels and looks tough plastic material. It has four self-tapping screws, so I have to be careful taking them out and specially when putting them back in.
The components that stand out are the two pieces of small 8-pin IC VM7205 (pic Pila002), two pieces of what looks like High Current Voltage Regulator (pics Pila009 & Pila010) that are covered by aluminum heat sink, two pieces of large white ceramic resistor and an assortment of other resistors and diodes.
Everything is soldered to the circuit board and it is fitted into the case through four holes which also served as the screw holes and covered by round rubber foot covers.
There are no dangling wires to worry about nor circuit connections that might get broken as you take the circuit board out after opening the case. All of the electronic components are soldered to the circuit board. The pieces that you might lose are the four screws.
According to http://www.vimicro.com/products/analog_ic/index.html
Here are the pictures;
Pila001
Pila002 (with 2 pcs. VM7205 ic)
Pila003
Pila004 (with 2 pcs. big white ceramic resistor 2WR22J)
Pila005
Pila006
Pila007
Pila008
Pila009 (with 2 pcs. High Current Voltage Regulator covered by aluminum heat-sink)
Pila010 (with 2 pcs. High Current Voltage Regulator covered by aluminum heat-sink)
VM7205 series advanced Lithium-Ion (Li-Ion) and Lithium-Polymer (Li-Pol) Linear Charger ICs are designed for cost-sensitive and compact portable electronics. They combine high-accuracy current and voltage regulation, battery condition monitoring, temperature monitoring, charge termination, charge-status indication, and internal impedance compensation in a single 8-pin IC. It is the best suitable device to be used in the PDA, mobile phones, and other portable devices.
Pila001
Pila003
Pila005
Pila006
Pila007
Pila008
