milkyspit
Well, it all started one dark evening here in Milky Labs drinking too many cans of Flashahol (the cheap ones to boot!) with my old buddy whose identity I'll protect by simply calling him the "Lathe Monster." /ubbthreads/images/graemlins/wink.gif Under the influence of so many photons, we got to talking, and hatched our nefarious plan. Why? Because we could. Muahahahahahahahaha! /ubbthreads/images/graemlins/mad.gif
This was truly a Frankenstonian creation. I took the EverLED that had served me well for so many days of a more innocent existence, strapped it onto a table, then the Lathe Monster and I grafted it into a new body... the... the body of... the... (gasp) the MiniMiniMag. (lightning crashes outside the window.) /ubbthreads/images/graemlins/mad.gif /ubbthreads/images/graemlins/crazy.gif
The Lathe Monster contributed the ring... a ring of AWESOME POWER. As the ring slid around the EverLED, I could feel my spine tingle, and the hairs on the back of my neck stood on end. Somewhere a scream was faintly heard. It was at this moment that the EverMag was born. /ubbthreads/images/graemlins/eek.gif /ubbthreads/images/graemlins/faint.gif
Following are some photos of the operation and its aftermath. Warning to those with weak stomachs: turn back now. /ubbthreads/images/graemlins/eek.gif
Here are the parts used in the surgery. Note the Lathe Monster's custom MiniMiniMag (MMM) barrel, the custom EverLED ring, and the cut-down MiniMag reflector...
The ring slipped around the EverLED and kept if from flopping to one side inside the MMM barrel. Immediately after the surgery, the subject was able to stand up, candle style...
Here is the EverMag with some other test subjects from the lab. Left to right is the MMM with a standard MM+ sandwich and NX05 optic, "Mr. Blue" featuring a MM+ R2H sandwich with NX05 optic, and EverMag using a modded MiniMag reflector...
The same lights, in the same order, exhibiting their horrific powers. Note that Mr. Blue is clearly the strongest of the three. The door panels interfering with the beams of the other two weren't the wisest idea. Still, the EverMag gives the standard MM+ sandwich in the MMM a run for its money...
Before we condemn the surgery to failure, the EverMag has some tricks of its own. Powered by a single AA NiMH rechargeable battery, the EverMag draws only 415mA midway through its runtime, suggesting a rough estimated runtime of perhaps 4 hours. Plus the EverMag can be focused. At one point, the square shape of the LED die is clearly visible...
But if we keep turning the head, shortly before the light turns off we find the sweet spot...
The EverMag has one intangible going for it, too. The Lathe Monster has infused it with a strong dose of quality. It feels good in the hand, compact yet solid, with good heft and the smoothest twist action of any MiniMag I've ever used. It wants to be carried.
Beware the EverMag! /ubbthreads/images/graemlins/ooo.gif
