I just bought my ARC AAA. However when I measure the V/I curve, it seems that the circuit inside is only voltage step up but not voltage regulation. My measurements are :
V=1.50V I=240mA
V=1.41V I=240mA
V=1.33V I=230mA
V=1.27V I=180mA
V=1.21V I=140mA
V=1.15V I=95mA
V=1.07V I=77mA
V=1.00V I=73mA
V=0.91V I=60mA
V=0.82V I=55mA
This V/I curve showed that the input power goes down as the voltage. The light output should also go down as the voltage.
In a true voltage regulating step up circuit, the output voltage to the LED (which I cannot measure as it is sealed) should keep constant. Input current should increase when input voltage decrease, this is to provide same power to the output. Usually input power goes up slightly as voltage goes down, because efficiency is worse at lower voltage.
Without a regulating effect, the LED flashlight cannot keep constant light output while the battery voltage drops.
I don't have a meter to measure the luminance. Can anyone tell me whether you observe the luminance drop as the battery run out.
I want a Flashlight with TRUE constant light (with regulator circuit). Does any ARC flishlight produce constant output during most of the battery life ?
Any other measurement on Arc AAA is most appreciated.
V=1.50V I=240mA
V=1.41V I=240mA
V=1.33V I=230mA
V=1.27V I=180mA
V=1.21V I=140mA
V=1.15V I=95mA
V=1.07V I=77mA
V=1.00V I=73mA
V=0.91V I=60mA
V=0.82V I=55mA
