tvsinesperanto
- Joined
- Dec 25, 2013
- Messages
- 19
Hi,
I'm after a really bright EDC light & one of the lights on my short list is the a Fenix PD35. However, I have some concerns about it's durability & I'm hoping that someone who owns one can allay or confirm my fears.
I've never actually seen a PD35 in real life, just pics & videos on the net, so I may be way off base, if so please say so. That said however, it seems to me that the rubber switches, particularly the side switch, could be a weak point & break/wear out fairly easily. The side switch appears to be a soft touch rubber type rather than a tougher hard plastic (like on the Olight S10/20 Baton for example) & I'm concerned that this could be pierced or cut by sharp objects or will simply wear thinner & thinner through use to the point that it splits. I'm not thrilled about the rubber tail switch either but that at least seems to be a bit more robust & is protected somewhat by the end cap.
My main concern is damage incurred while it's in my pocket as I usually like to carry my EDC knife & a couple of other hard objects in the same pocket.
My other concern, albeit a far more minor one, is the Bezel which, if I'm not mistaken, is made from Aluminium & not Stainless Steel. It seems to me that this could result in a hell of a lot of dings & dents, especially in my pocket. Has anyone found this to be the case?
Can anyone who has had experience with using & carrying this particular model tell me if I am right to be concerned about this? My EDC gear tends to get a lot of use & takes a beating, so the last thing I want is a fragile light. In fact, it needs to be bulletproof to survive the punishment I'm likely to put it through.
Another question... How does the PD35 carry as an EDC light? It's bordering on the upper limit of what I'd consider a practical size for an EDC so I'd be interested to know if anyone thinks it's uncomfortable or cumbersome to carry (I'd be carrying it in my front jeans pocket using the pocket clip in case it matters).
Thanks in advance,
TV
Thanks in advance,
TV
