Two-stage Tri-LuxIII Aleph3/SO17XA (201-262 Lumens)
Aleph3 head, Aleph 2x123 Power Pack, McE2S two stage switch, 3x LuxIII TW0J emitters + 3x IMS SO17XA reflectors, custom made heatsink and BadBoy500 driver module running on 2x AW LIR123 batteries. Will also run on 2xPila150S, 2xLIR 17500, 2xCR123 and 3xCR123 batteries when using the appropriate power pack.
Heatsink is epoxied into the Aleph head.
Driver module can be removed after desoldering the wires to the leds.
Lumens output: 3x (67.2 - 87.4) = 201.6 – 262.2 Lumens.
Lux reading at 1m using Meterman LM631: 330 Lux on low (22ohms); 2450 Lux on high.
Runs in regulation as long as Vin > 4.5V.
Runtime in regulation at max brightness without interruption
2x AW LIR123's (750mAh): 41 - 45 minutes
2x Pila150S (1000mAh): 75 minutes.
Alauda's review can be found
here.
