geepondy said:
"Into Thin Air" by John Krakaur is an excellent book on Everest. People still die up there including this year. Anybody else have a good Everest book to recommend?
That is one of my favorite books. I got it from my dad and first read it in 6th grade.
As some people were saying earlier, the thin air would be a problem. If you took a person from sea level and put him on the top of everest, he would be dead in a couple minutes. Even the oxygen that they breath from tanks above 25,000 would not help you that much. When you are breathing oxygen from a tank at the top of everest, it is equivillent of breathing air at 26,000 feet. You would probably still die pretty quickly.
The reason that some people are able to climb to the top with out oxygen is because they get acclimatized to the thin air. This is(or was, have not checked in a while) pretty rare. Above 25,000 is known as the death zone I think, for a good reason. Usually when you climb everest you don't just start from the base camp and climb straight up to the top. You might climb half way to camp 1, and turn around to go back to base camp. You go a little farther each time, staying at different camps, while maybe climbing up to another camp, just to climb back down the next day or that same day, until the final push. It takes a few months to do al of this.
There are only a few weeks of the year that everest is not being blasted with 200 mile per hour winds of the jet stream.
Most of this info was from the book
Into Thin Air I would recomend this book to any one.
