Re: Where to but Quark AA2-T & Zebralight H51F
Hi Dean ... I've tried various combinations ... I've worked (govt) through several disasters (Santa Cruz flood-'82, Loma Prieta, Sierra blizzards) ... I have a combination of lights for different uses: D-Cell led lanterns (coast or similar w-100 hr runtimes and low setting capable), maglites (2&3 D) w/malkoff dropins (6-hr runtime, 24 to full drain) + optical-plastic lens + xtreme-cap (knob type w-toolsteel-glassbreaker + $13 aluminum SMO reflector from Kaidomain (S006165) ... I've recently added the 9AA/3D OddModds adaptor in the 3.5/4.6 configuration to allow use of 9 Energizer L91 AA batteries (this allows you to store the light in a trunk or home and forget it for years without leakage or low-power issues, and allows for use of different battery types, it also makes the light very light weight). At work we have been trying out the "Light-For-Life" 270 lumen 'battery-less' flashlights (vehicles and desks) since they will fully recharge from a cigarette lighter, or plug in, in 60-seconds. They are a very interesting option since they use some type of capacitor and can be very quickly charged to full for about an hour runtime. It's also important to consider post-disaster needs if you may encounter an explosive atmosphere (confined spaces)... in that circumstance the light would need to be intrinsically safe (no ignition sources) ... see lightboxes, etc.
I can say that the Malkoff mag dropins easily outperform all of the dropins that we tested (A/B) for throw and light intensity. Interestingly, some of the competing mag bulbs/dropins rated at 800+ lumens, were a dismal second to the Malkoff dropins rated at ~ 270 lumens ... go figure !! I've become a die-hard admirer of the Malkoff dropins because they are solidly built and outperform for emergency use. My advice here is to build your emergency equip step-by-step, don't buy Lamborini's, just try to buy very-good quality that performs well and gives excellent runtime.
Last, but not least, I have found that for home, on the different floor-levels, the DATEXX "Sentina" smart rechargeable wall plug-in lights are absolutely fantastic ... very very long lived (never have had one go bad) ... they provide very sufficient light to see-by/evacuate ... they can be set for motion sensing and power-outage-auto-lighting, and have worked fantastically during winter outages, night-trips to the restroom, and/or earthquakes/disasters. Keep equipment as a long-term goal ... budget over time with a few 'foundation' solid lights ... I like the option for lithiums - no corrosion/leakage, and easily 10+ years storage at close to full power. Your "rechargeables" are of course an excellent way to go.
Best R's
- Den
