Re: Where to but Quark AA2-T & Zebralight H51F
Note that not all ZL AA lights are equal performers in this respect. Based on my testing using a very depleted alakline AA, my Mk I H51 (GITD ring, no clip) is noticeably better than my SC51, SC51c and H501 (old model). Of course it may just be the LED in this particular light has a lower than average vf.
That's probably it. The Luxeon Rebel used in the ZebraLight "c" models, for example, has a typical V
f of 3.0 V at 350 mA, a minimum of 2.55 V, and a maximum of 3.99 V, which is a pretty wide range, I think. The V
f range for the CREE XP-G used in the other models isn't given in the data sheet, but the typical voltages are identical, so it's quite possible for one particular LED, regardless of whether it's an XP-G or Rebel, to have a meaningfully lower V
f than another. LEDs will vary in overall output efficiency as well, but not as much as they do in the minimum voltage required to get any light out of them at all, apparently.
GaAslamp, I double checked that with the same battery (saved it because I thought it was cool) and I Was Wrong.
The initial flash that I described is some capacitor thing in the light itself.......
(drum roll)
The battery will do much more than make a flash, it will tolerate being turned on to Med level with a double click (first click defaults to High with a momentary flash, second of double click sets level at Medium.) There is a brief flash, three or four seconds of dimmer brightness and then it goes into a flickering low. Minutes later typing this the light is still emitting a sickly dim flickering glow, the light dimming briefly about 8 times per second.
I put the battery in the old CMG right before trying the H51Fc to give the CMG more of a chance, nothing though.
Even more WOW!
oo: Or maybe the boost circuit in the CMG is not nearly as efficient as we had suspected.
Also just as Gregozedobe mentioned that the ZL led might have a lower vf (I don't know that term yet) another variable is of course that this particular CMG might be Less efficient than an average Red CMG for whatever reason.
That's a possibility with regard to the red LED. For comparison, the usual V
f range for these is 1.6-2.0 V versus the 2.55-3.99 V range given for the Rebel LXM3-PW51 LED used in your H51Fc. If your red LED's V
f is 2.0 and your white LED's V
f is 2.55, for example, then the superior efficiency of the H51Fc can make up the difference, although the red LED is still inherently easier to light up. I was already somewhat surprised that your H51Fc lit up at all, but being able to run on Medium even for a moment is even more impressive. :twothumbs
I'm not that up on the techo side myself, but my understanding is that Vf (forward voltage) is the voltage that a particular LED needs to light up properly. From what I remember white leds usually take more voltage than red leds to fire up, which is why lights with red leds have a reputation as being good battery vampires.
As pointed out above, red LEDs are still easier to light up, although the difference is not quite as pronounced as I had initially believed (on the average, yes, but not at the adjacent extremes).
