paintballdad
HA is hard anodized olive drab and HABK is hard anodized black.
... the L4 is perfect for doing vessel checks and other tasks due to its size.
The only thing I need to figure out is do I get a KX2C head to upgrade the old 100 lumen head or do I buy a P60 host? I can't really see buying another G2ZL when I don't carry a duty belt.
E-series = perfect.
I'm looking at picking up a E1E Executive Elite for $55...good deal? And if so, what's the first thing I need to do to pump lumens?
You've got a handful of options. Easiest one is to get an Optics HQ / TLS Q5 LED replacement head. Huge increase in lumen output, but the carry-clip becomes useless since the TLS head is a bit longer than the standard E1E head. With the TLS head in place, the clip becomes simply an anti-roll feature. If clip carry isn't important to you, the TLS head is a great option.
If you want to keep the stock E1E head in place, you can send your light off to Scott (MilkySpit) and have him turn it into a Milky Red-Eye. One Hell of a sweet upgrade! If you'd prefer, he can alter the beam profile so that your E1E gives a ton of flood with no hotspot. (A single-cell Milky RoomSweeper).
If you'd prefer not to alter your E1E into an LED light, you can get a Lumens Factory HO-E1R 3.6 volt 50 Lumen high-output lamp. Replace the stock lamp in the E1E with this one, and be sure to use only a rechargeable CR123 cell (RCR123) with the lamp. This is the least expensive route, but also yields the smallest jump in output. Besides the lamp assembly, and one RCR123 cell, you'll need a charger for the cell. Check out Lighthound.com if you go with this option.
Check out the links below for the other two options...
TLS head. (Scroll nearly all the way down to where it says, TLS CREE Q5 LED Conversion Head for E1. Then click on the image). ~
http://www.opticshq.com/page/Optics/CTGY/Surefire-Accessories
Milky Red-Eye. ~
https://www.candlepowerforums.com/threads/211483
Milky RoomSweeper (2-cell version). ~
https://www.candlepowerforums.com/threads/209239
It is reading these threads that makes me feel so behind and inadequate. I only have an E1B, 2 E1Es and an E1L.
Thanks bud. Is there a particular RCR123 and charger that you would recommend from lighthound?
Hmm...
A number of people have claimed to do it. Maybe they had to modifiy something else as well?
AS noted, McGizmo did some a few years ago. I just snagged one, will get some pics up soon. He removes the driver and bores the body. LE has to go a bit farther forward in the head as compared to a regular Aleph or E Series.
Here are a couple of random pics that do not reflect the current collection:
Surefire.Who makes that tailcap on the L1?
Looks like Milky did the resistor mod to it to lower the low. I just did one with a 100ohm resistor and it is super low. I plan to do a 20 or 30 ohm next. I need to label it just like that one. I got clear label tape for just that reason.Who makes that tailcap on the L1?
Surefire.
Looks like a stock tailcap with lanyard ring that Milkyspit modified and tagged.
