Very good comparison right there my friend.
It would be if the numbers were correct. Unfortunately the runtimes that Mr. LED quoted are not up to date. Henry has neglected to update the chart in the FAQ.
Here are the correct ones in
red:
[as per specs on each actual HDS product page]
Take the HDS 250 lumen and the Zebralight SC64w in comparison. Both using 18650 @ ~3300mAh:
HDS @ 250 lumens - 3.5 hours
5:45 of tactical runtime (down to 50 lumens)
Zebralight SC64w @ 264 lumens - 6.3 hours
HDS @ 9.4 lumens - 91 hours
not sure as not listed
Zebralight SC64w @ 8.5 lumens - 175 hours
Now let's compare CR123 runtimes:
HDS @ 250 lumens - 1.5 hours
2.0 hours (ANSI)
Zebralight SC32w @ 245 - 1.6 hours
HDS @ 9.4 lumens - 28 hours
30 hours (ANSI)
Zebralight SC32w @ 8.5 lumens - 70 hours
Also bear in mind that with HDS as each light is individually calibrated the runtimes listed above are the bare minimum, usually you will get much more as per:
Why do flashlight runtimes vary?
The efficiency of LEDs vary from one LED to the next. Therefore the amount of power it takes to generate the same amount of light will very from one LED to the next. We have chosen to hold the light output constant from one flashlight to the next. This results in constant light output but causes variations in runtimes from one flashlight to the next. We specify a minimum runtime at the rated light output. This results in a statistical distribution with the typical runtime being 10 to 15% higher than the minimum runtime.
So based on the above runtimes and info it seems that the HDS lights are actually more efficient than Zebralights on the high end output.
Anyway my point wasn't to turn this into a HDS vs a Zebralight comparison, it was just to highlight the quality of technical excellence in the whitepaper and the advantages of a UI that enables you to instantly get to maximum thereby 'seeing' an equivalent as with an actual 1000 lumens.
As it stands I don't currently own any Zebralights as I have always been put off by their QC, their 1 year warranty and warranty has taken a couple of months for turnaround in some cases because they are really just a Chinese flashlight company with a US business address. That's not to say that I dislike the company, in fact I may end up getting one of their AA lights in the future, but I just wouldn't use it as my primary EDC light.
