38mm Head with a twist.
Mirage_Man
Florida
This head was a design collaboration between myself and Daniel (easilyled). Daniel wanted me to make a unique 38mm reflector based head to go on one of TB's famous croc 18650 bodies. During the making of the head I screwed up and just about trashed the project but didn't. The result is the unique bezel design. It's strange how screw ups can become something really special.
I was waiting to see what this beauty was going to look like. Absolutely gorgeous, never expected that! Awsome job! :twothumbs
Wow I'm speechless. That's amazing work Brian and has exceeded all my expectations.
I think they call this serendipity. :thumbsup:
Many thanks for all the time you put into making this beauty.
Thanks guys. It's nice to have my hard work appreciated.
Thought some of you might like to see some pics I took during machining. Obviously there's a lot more that I didn't take pictures of. But at least there's a few.
WOW! Where's the join in the first photo? Invisible I reckon. Do you make the head in two pieces then assemble before the outside work is done?
Good job.
Beautiful work Brian.:bow: And great photo's too.
Colin.
PS. Can you please stop posting pictures of your chuck now - I'm feeling very inadequate :green:
I'm honored to be given the priveledge of giving life to this special light.
This special light requires a special LE. Although this head is an Aleph style, it's a custom which requires a custom fitted LE which needed to be shorter than the common Aleph LE. A XRcan was shortened from top & bottom of the threads in order to fit the head & to allow the head to mate the body "seamlessly". Because the XRcan was shortened it also had to be bored deeper using a custom heatsink to allow the P7 to sit lower in the XRcan.
The owner wanted a P7 to be driven at least 2A on high using a Draco UI FLuPIC. This was a task in itself since the Draco UI does not have direct drive burst & because of the shorter LE there was limited space for the modified/boosted FLuPIC. I delivered what was asked & to do so was not the easiest thing to do as you will see in the photos below.
This is by far the most beautiful light I have ever worked on yet! I'm not so sure it can be topped? Excellent work by Brian (MM) & Scott (TB) as well as great tastes from the owner! Hope the owner enjoys! :wave:
-Mirage_Man Ti 38mm head
-TranquillityBase Ti 18650 body
-Erin Ti tailcap
-Erin 38mm reflector
-SSC P7 DSXOJ
-Modified FLuPIC Draco v2 UI
-Modified XRcan & custom heatsink
-2.5A high (2.7A peak), 13ma low w/ AW 18650
Fantastic work once again Will. I am privileged that you agreed to do it for me.
I am fortunate enough to have witnessed your exemplary work on many occasions now and CPF is blessed by your talent.
Many thanks for bringing all your skill, precision and expertise to bear. :twothumbs
Thanks once again to Mirage_Man for one of the nicest heads I've seen, TB for his superb TBSB bodies
and to erin0919 for the nice tailcap housing and reflector. :)
