Morepower!
Ok, I decided to put one of these kits to the test, mainly for my own curiosity. The tests were performed using a PSU capable of supplying 40A @ 16V DC continuously and is voltage regulated, so no chance of voltage lag, a Lux meter from DX and a Protek 506 True RMS DMM. I decided to post the results for anyone who might be interested to know, sorry if i've burst anyone's bubble. I know I've burst my own.
The set up:
Now for the bad news:
INPUT: 14.8V
BALLAST
Start up current: 5.51A DC
Run current: 3.66A DC
Start up voltage: 14.8V DC
Run voltage: 14.8V DC
BULB
Start up current: 1.69A AC
Run current: 0.49A AC
Start up voltage: Unmeasurable without a High Voltage DMM, with test leads attached bulb won’t ignite.
Run voltage: 86.3V AC (106.8V AC on a non RMS meter)
Wattage at bulb: 42.29W
Lux at 300mm from bare bulb @ 15mins runtime: 5,320
INPUT: 11.1V
BALLAST
Start up current: 7.41A DC
Run current: 5.24A DC
Start up voltage: 11.1V DC
Run voltage: 11.1V DC
BULB
Start up current: 1.67A AC
Lux at 300mm from bare bulb @ 15mins runtime: 5,220
I didn’t bother doing a 12V test after seeing the results between 14.8V and 11.1V, it’s pretty obvious the ballast is regulated. I also don’t read too much into the difference in Lux, I just took the measurements to see if there were any significant advantages in running 14.8V vs 11.1V. I don’t know if a bulb with a different arc length would pull more current out of the ballast or not ?
The set up:
INPUT: 14.8V
BALLAST
BULB
INPUT: 11.1V
BALLAST
BULB
