Anodizing Titanium
Tom Anderson
Manchester, PA
Since I'm a new member here, I thought I'd share my mini-tutorial on anodizing titanium.
The photos show some of the knives I once built, but the principles apply to other titanium gadgets as well. ;)
The process of anodizing titanium involves immersing the object to be colored in a container with a titanium cathode inserted and filled with an electrolyte. Passing a DC charge through the electrolyte solution will cause a microscopic oxide film to adhere to the part. The thickness of the oxide film determines the color.
Attached is a color chart that lists the various colors obtainable through the various effective DC voltage ranges:
Note that these colors can also be obtained by heating the part to create the oxidation, but that process is not as accurately controlled.
The equipment used consists of the following:
1. A DC power supply that has a range of 0 to 125 volts. The wattage (amperage x voltage) of the power supply will determine the size of the part that can be anodized as well as the speed of anodization. For most knife handles (approximately 6" long or smaller), I would recommend using a 1-kilowatt DC power supply (approximately 7 amps x 150 volts).
2. A non-conductive container, large enough for the cathode (see #3) and the part to be anodized.
3. A strip of titanium to be used as a cathode. The surface area of this strip must be greater than the surface area of the part being anodized. For safety, the cathode can be covered with nylon webbing to avoid accidental contact with the part during immersion.
4. Electrolyte solution. This can be a simple solution of 5% trisodium phosphate in distilled water – enough to fill within 1" of the top of the container.
5. Leads for the + and – terminals between the DC power supply, cathode (titanium strip), and anode (see below).
6. Anode: This is a small hook made from titanium wire to which the part is attached for immersion.
7. Thick rubber gloves to be worn as a safety measure during the anodizing process.
8. A bottle of cleaner (Windex ammonia-based window cleaner works well).
9. A small paintbrush with a metal ferrule. This is used for reverse-polarity brush anodizing described later.
Equipment setup and use:
NOTE: Exercise caution when working with the power supply turned on to avoid electrocution. Always wear rubber gloves when the power supply is turned on. Do not attempt this process while working on an electrically conductive surface!
Fill the container with the 5% TSP/distilled water solution (electrolyte). Attach the cathode (-) lead from the DC power supply to the cathode – making sure the connection is well above the electrolyte level.
Attach the anode (+) lead to the titanium hook. Exercise caution not to bring the two leads together.
Turn on the power supply and adjust the voltage to achieve the color (as shown on the attached chart). Turn the power supply off.
Clean the part to be anodized with the ammonia based cleaner. Attach the part to the titanium hook/anode, and submerse it in the electrolyte bath.
Turn the DC power supply on until the color appears on the part. Turn the DC power supply off when the color is achieved and before removing the part from the electrolyte bath.
Re-clean and dry the part to remove any traces of electrolyte.
Multi-Stage Anodizing:
Applying different colors to a titanium part can be achieved using the equipment listed previously with several different techniques. Besides ensuring safety, the most important thing to remember is that the oxide film (color) applied during a higher voltage session will remain when applying an oxide film (color) at a lower voltage setting. For instance, you can submerge a titanium part that had been partially masked when a 40 DCV color (powder blue) was applied and apply a 25 DCV color (purple) without affecting the powder blue color.
I have attached several photos illustrating the results of various multi-stage anodized titanium parts.
This knife has had multi-stage anodized scales that were accomplished with the following (basic) steps:
1. Anodize the engraved bolster area with gold at 15VDC. Sand off the top to make it look like gold-filled engraving.
2. Mask off the engraved bolster area, apply a light coat of spray glue to the "overlay" area.
3. Anodize the light blue color at 43VDC.
4. Remove the spray glue and reapply another light coat.
5. Anodize the dark blue color at 28VDC
6. Remove the spray glue.
7. Anodize the purple color at 19VDC.
NOTE: All parts were anodized using the immersion method described previously. The stepped pivot screw collar is a separate piece, anodized at 28VDC.
This is another example of multi-stage anodizing. Here the overlays were anodized at 65VDC to achieve the green-gold color in the file work. Then, the tops of the overlays were sanded, cleaned, and re-anodized at 28VDC to achieve the blue color.
Reverse-polarity anodization:
This is another technique using the same power supply and electrolyte, but using a paintbrush with a metal ferrule to "paint" the color on the part. The negative lead (cathode) is attached to the ferrule on the paintbrush and the positive lead (anode) is attached to the work piece. Again, rubber gloves must be used to avoid electric shock.
In the above photo, I'm anodizing the slots in a pocket clip using a small paintbrush. I created a "rainbow" effect by gradually slowing down each brush stroke. The following photo shows the results.
I carefully sanded the top surface of the pocket clip to remove any overruns, and cleaned it again using ammonia-based window cleaner. The next step involved reconnecting the power supply leads to the cathode strip (-) and the titanium wire hook (+), setting the voltage at 28VDC, and submerging the pocket clip in the electrolyte bath. The following photo shows the results.
Because the slots were anodized at a DC voltage setting greater than 28, the colors remained after anodizing the rest of the part at 28VDC.
The following photo shows the standard bath setup used to apply the blue color on this pocket clip.
The following is a good reference link to the process of anodizing titanium and other reactive metals:
http://www.reactivemetals.com/
General notes:
Anodizing titanium is a different process from anodizing aluminum. There are no dyes or acids used and, thus, the range of colors is limited. (For example: bright red or black cannot be achieved when anodizing titanium with the process described herein.)
Other differences between the processes used in anodizing titanium and aluminum include:
1. The surface of the titanium part is not hardened (like with TYPE 3 anodization of aluminum), and can be easily scratched.
2. A microscopically thin oxide layer that is refractive creates the color.
3. The color will dull from skin oils (or other dirt) during handling. Removing the skin oils with an ammonia-based cleaner, acetone, alcohol, etc can restore the color.
Hey Tom, good to see you over here.
Where did you source your power supply from? It sounds like a beast of a unit, far better than a Variac Rectifier and Caps.
Great to see you here, Tom. Welcome to CPF! Fantastic tutorial, thank you!
There is a thread on anodizing Ti in the McGizmo subforum you may find worthy of a glance.
:thumbsup:
Tom,
Awesome tutorial! :twothumbs
Great to see you on CPF. I love admiring all of the amazing work on your website.
:thumbsup: john
Good to see you here as well Tom, nice tutorial.:thumbsup:
Now go on and post more of your stuff in the gadgetry section!
I actually have several DC power supplies. The three in my "Tower of Power" cabinet are Sorensen brand. The unit shown on the top is solid state and a lot lighter than the DCR units below. All of them work very well - but I like the digital meters on the DCS150-7 unit. (Besides, it puts out 1Kw of power! :D )
:thumbsup:
I don't know why I didn't register here before. :thinking:
I'll have to check out that thread on anodizing. Thanks!
Tom,
:thumbsup: john
Thank you, John! There's a lot of great information and cool people here on CPF! :cool:
I don't want to come on too strong and risk irking the moderators. After all, they were kind enough to let me in and I'm very thankful for that. ;)
If you see anything of mine you'd like to talk about - or if you just want to know how I build and finish my titanium gizmos - I'll be happy to answer your questions. :)
So Tom, the unit will only provide 7A at any voltage though correct? Which is 0-1Kw but say at 50V only 0-350w depending on current selection?
That's right. I can dial in up to 7 amps of power throughout the 0-150VDC range.
The larger the amperage, the larger the workpiece can be.
Most of the anodization I do is actually under 105VDC.
I have played with anodizing titanium and have never seen my power supply go over maybe 0.1 amps. Why do you need a 7 amp supply? I anodized a hole light and the amps draw was almost nothing.
Excellent work BTW!
Mac
Nice to see you here Tom! Your work is amazing & I envy all of it. Love your shop too & your Ti stock/collection is amazing! So far you have the biggest piece of titanium I have ever seen on a mid size lathe! :twothumbs
Excellent work BTW!
Mac
I also have an Agilent 1/4amp DC power supply that I bought before getting my Sorensen units.
With the more powerful supplies, you can anodize much bigger pieces. ;)
Thanks! That 37# hunk of 6AL4V was the biggest piece of titanium I've ever turned. :D
Very very nice work. Thanks for the tutorial as well.
Thank you! :)
I have a nice Lambda 100v 10amp supply :)
Where are the pictures of your shop?? That is a nice piece of Ti you got there!!! what where you making??
Mac
That is freakin' preposterous. :twothumbs :bow:
I thought 6Al4V stock over 2" was reserved for the nuke industry. Pulling strings, Tom?
Welcome Tom, great to see you here! :D You are a true asset to any forum and your products are above and beyond.
Mac
I'll post pictures of the rest of my shop equipment later - probably in a new thread.
I just cleaned the big titanium bar up for now. I have a project in mind, but I'd rather not say what it is until I know everything will work out the way I want it to. There's still some Engineering and tool requisitions to do. :thinking:
Too many projects. Not enough hours in the day. :rolleyes:
Although the acquisition of that titanium bar had nothing to do with it, I once built reactors for the US Navy. I also built Naval chillers, so I guess you could say I worked both the hot and the cold parts of the ships. :D
Thanks, Dan! :)
