After a couple of posts from member Justin Case, I decided
to have a go at building a Tower Module with a Cree XP-G R5
Without his advice I never would have attempted this build
so kudos to Justin for spoon feeding me :D
The R5s I received where purchased by member R@ndom from
Cutter. These are the R5s mounted on a 10mm board.
For the R5 to fit thru the Turbo head opening, the board had to
be reduced in size. I used pair of snips and to finish off, a file.
For size comparison, the emitter on the right is a SSCP4
Unfortunately, I did not have any spare empty Tower Modules
so I had to cannibalize a previously build Module
Here is the unfortunate donor
I used a very sharp blade and managed to remove the old emitter
intact.
The R5 has now been AAed to the Module
Now sitting inside a KT-4 head :devil:
Before and after whitewall beamshot ..... hmm they look more or less the
same in the photo ?
From my own personal observations, I have build Tower Modules using
SSCP4s, Diamond Dragons and K2 TFFC they all have similar looking
beams. The R5 and P4 are almost identical, it is a shame I had to cannibalize
the Module with the SSCP4, otherwise I could have taken
some outdoor beamshots comparing the two.
When compared to a Module with a K2 TFFC emitter, the R5 is brighter
and going from memory the K2 TFFC was brighter than the P4.
intact.
same in the photo ?
