Any lights out there with no Hot Spot?
Solar Powered Pickle
Anyone know of any LED lights that have no Hot SPot in the middle? Just a bright even spot? or even just a very smooth transitionless spot from the inside to the edge?
Any LED with a beam diffusing filter in front of it. An FM34 in front of a G2L for example, will show no trace of a hotspot.
The new Coleman Exponent 123A lights have a minimal hot spot as compared to a L4 and a slightly larger flood area as well.
Central Tools makes a worklight and a flashlight that use an optic [lens] that gives a perfectly even beam. IIRC the flashlight is called the FlashFlood. The beam is bright and even, but not that wide compared to the L4, as the optic concentrated the light output into a smaller area. I have the worklight and it is fantastic.
A cree light without a reflector or optic.
Stu
Just about any wide angle
LED without a reflector or optic lens
i.e. this lumileds K2
(Lambertian) with out any lens or reflector
Any flashlight without an optic/reflector or a specially designed flood optic.
Zebralight and Central Tools comes to mind.
Even the L4 has a hotspot, just a very big one.
How about the DX (SKU 5979) "Romisen" 1xAAA light, it looks to have a large hotspot. Although I not own one and do not know about the beam smoothness.
An aspheric lens, mounted semi-close proximity to the emitter will project a uniform white circle with no hot spot. YMMV though depending on the projection characteristics of the emitter, and the geometry of the aspheric. You could (forexample) get the opposite effect... a donut hole projection.
It won't be a "pure" flood though, at least not to the extent of just the bare emitter.
